eSAVE Mode Temporarily Unavailable
madmax1618
Taylor
Redlands, CA
21 Sting Gray JLUR 4xe, 99 Chili Pepper Red XJ
I've seen quite a bit about electric mode unavailable, FORM and all that, but I was a little confused today when my Jeep told me that eSAVE Mode was temporarily unavailable. Weird that it would protest running just the ICE.
Anybody else experienced this?
laroo
FL
2022 JLUR 4xe
Was your battery above 95%? You can't charge until you're below that number, and you can't charge higher than 95 using esave. I don't remember ever seeing that message though.
madmax1618
madmax1618
Taylor
Redlands, CA
Battery was ~30%. I'd just driven about 15 miles in Hybrid mode on the freeway so engine was on and off and warmed up. Stopped at the store, got back in and thought I'd save a little battery for tomorrow, tried eSAVE then it happened. Tried electric, which worked fine, then tried eSAVE 2 more times before it finally stuck.
Mgg253
Michael
2021 JLUR 4xe
Watching - keep us up to date! First I’ve heard it
laroo
FL
2022 JLUR 4xe
Weird... Maybe just a glitch, or maybe some rare condition in the hybrid software. I don't think I'd worry about it too much unless it continues to happen. But I've never seen that in my 4xe.
madmax1618
madmax1618
Taylor
Redlands, CA
Will do.
Probably a glitch, yeah. Maybe heat related, it was 105 out and heat has caused a few other glitches in the past.
Bmeister
Chicagoland (heart is in SC)
2021 JLUR 4xe, 2012 JK, 2011 WK2 5.7
If the battery was heat soaked and its cooling system hasn't had enough time to cool it to a good range to enable charging, that could cause that message. True for any lithium pack. Atmoshperic temp is not necessarily the same as battery temp. The good thing about this is Jeep engineers have thought about the system preserving itself from harm for longevity.
Fenny
Fenny
Western,NY
2023 jeep wrangler JLU Willys 4xe, 2021 volvo xc90
My 4xe experienced this issue today. I had taken my Jeep to Vermont to do some off roading And the battery was around 87% and I was in esave with battery charging. The issue happened while the outside temp Was about 75. I was on a long slow trail when it happened the Jeep switched to hybrid mode. After finishing the trail and back on the road and moving I was able to switch back into esave without any further issue. The only thing I can figure out is that one of the electronic cooling systems must have gotten too hot without enough air flow through the radiator on a slow moving trail.
madmax1618
madmax1618
Taylor
Redlands, CA
I agree, I think heat is the culprit. I will say that it has not happened again. Though I have had a dozen software updates and a replacement battery heater module since then, so one of those could have solved it. I have had a few other weird things happen, and they were likely heat related too.
I've also found that certain situations where the engine idles or runs constantly at low speeds for a long time cause what I assume to be the clutches in the transmission to get hot. Smells like a slipping clutch for a minute when I get park and get out.
azjl#3
North AZ
I am sure glad we have brave folks like you all testing the e vehicles. Seriously, thanks.
Fenny
Fenny
Western,NY
i also noticed a smell of something hot earlier in the day but had no dash lights come on and all the gauges were in the normal range. We just drove to the top of mount equinox In hybrid mode and noticed the smell after getting out of our Jeep. I couldn’t trace the smell then but heated clutch sounds plausible. i thought heat soak was a thing of the past. I didnā€˜t realize the 4xe was a retro wrangler. ?
PatriotX
Midwest/Great Lakes
2022 4xe
You’re welcome.
Seriously, it’s been a trouble-free pleasure.
I can’t imagine the hell the early Pentastar owners went through, after reading the forum here….I feel good that I chose a more reliable platform.
madmax1618
madmax1618
Taylor
Redlands, CA
Happy to be a guinea pig. It's a pain in the ass sometimes, but mostly is a great Jeep. Honestly it's mostly a regular wrangler with a few more complicated bits, and EV tech has come a long way in the last 5 years.
