Electronic Traction Control
ASMSAS
Marlene
NorCal
Aviation
I’m not sure if this is the right location for thsu question:
This week I did a Jeep Adventure Academy day in Hollister CA. Due to all the rain is was mega muddy which made for an exceptionally awesome day. However I learned something new that I still don’t understand.
In 4L - When in mud, sometimes I had limited grip and one or both rear wheels would spin freely in the mud while the Jeep slid around a bit. I was instructed to keep the gas power on and even and after a few seconds the computer would do something and suddenly I would have traction.
What exactly was happening? Do other cars have this too (ie Audi)?
Jeep Wrangler JL Electronic Traction Control E80BA5F9-909F-4832-A039-9A2D83EB7C06
Jeep Wrangler JL Electronic Traction Control 51716059-99F6-42F2-A3E1-36EEBC0AB93B
Obi Wan
Obi
Tatooine, Outer Rim
starwars.fandom.com
2023 JLU SPORT S 2.0, 2004 TJ SPORT 5.3LS
Jedi Knight
This is called BLD or "Brake Limited Differential" and is outlined in the owners manual.
Jeep Wrangler JL Electronic Traction Control 1677420020870
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
In general what it comes down to is this. The computer (aka ABS unit) needs to see wheel spin or no wheel spin. Then it can make the decision as for what to do. If you are a standstill, it has no idea as to what to do until it receives information via each wheel speed sensor.
Your Audi works similar. So, if you are in a boatload of snow and stomp the throttle, you'll hear the ABS unit buzzing as it's trying to adjust the brake at each corner to get you the maximum grip that is available at the time. Depending on the AUDI, it might then use the Haldex unit to apply power to the rear.
ASMSAS
ASMSAS
Marlene
NorCal
Aviation
I think you mean then ASR on the Audi?
