Hi Cody6597,No. Once I reconnected the battery the freak out continued but in different ways. I cant get it started either. I know some said a cold start recall TSB was sent out but its 80 degrees in Houston this morning. Trying to trouble shoot before I call and have the darn thing towed. @JeepCares
I was running a Beta on my Tazer...and I think the Tazer left a relay open some where. I removed Tazer and jumped it. The Jeep started right up for me. This was back in Winter. I updated the Tazer off the beta to the stable version. Hasn't happened since. Good Luck OP!Not sure if you have a Tazer or not... one of your posts suggests you do. Definitely remove before taking to dealer if you go that route. I've heard scattered reports about parasitic battery drain with a Tazer but thought that all got sorted out. There are a number of threads in here on that topic. I would think that a dealer would be a better choice than Autozone (unless you have a really crappy dealer). If you suspect a bad battery the dealer could/should replace under warranty.
Thanks. I updated to the latest so hope it is not the beta.I was running a Beta on my Tazer...and I think the Tazer left a relay open some where. I removed Tazer and jumped it. The Jeep started right up for me. This was back in Winter. I updated the Tazer off the beta to the stable version. Hasn't happened since. Good Luck OP!
Thanks Jasmine. I did get it restarted and this morning it started up no problem. Will direct message you if it happens again.Hi Cody6597,
Where does everything stand since this post? Send us a direct message as we'd be glad to escalate a case for additional help.
Jasmine
Jeep Social Care Specialist
That's good to hear, Cody6597. I'll keep my eyes peeled for any future updates.Thanks Jasmine. I did get it restarted and this morning it started up no problem. Will direct message you if it happens again.
