Electrical/Tech folks: Help needed powering lockers!
ChattVol
Tennessee
JLU 4 door
I'm about to swap takeoff jlur axles into a jlus and need help with powering the e-lockers to a switch near the dash running seperate from the main system. The jlur e-lockers were apparently made by a Japanese company and have a 4 wire system instead of 2 and looks like this(courtesy of @TTEChris)
Jeep Wrangler JL Electrical/Tech folks: Help needed powering lockers! wdTyz6E
Jeep Wrangler JL Electrical/Tech folks: Help needed powering lockers! ej0zzr3
Jeep Wrangler JL Electrical/Tech folks: Help needed powering lockers! Vbkg3mn
I was thinking of using the linked Mopar jlur locker harness below that claims to allow your Wrangler JL's front or rear locking axle to be powered. You provide power and ground with your switch.
https://www.moparonlineperformance.com/product-p/77072413.htm
How would this work running seperate from main system? Any recommendations/advice is greatly appreciated.
jellis4148
Missouri
Can't you get the Mopar wiring harness, and wire it into the Aux switches? People use it so they can use the lockers in 4hi. Here is the part number: 77072413
ChattVol
ChattVol
Tennessee
JLU 4 door
Thanks...been researching this mopar aux switch to connect lockers.
https://www.allmoparparts.com/sku-y...F7IXwvroTpNNlU5X8aXLdOViOJevIBwsaAvByEALw_wcB
Would it work if I connected this locker harness to both locker inputs and then into the 15amp switches(I believe aux switch 3 &4)
https://www.allmoparparts.com/sku-y...1WAj0EfaJcI39jCAo4XTIDJQPzKvSCwUaAkmxEALw_wcB
Because the harness is a 4 wire harness(2 wires for sensors & 1 for ground & 1 for power), I would just leave the 2 sensor wires not hooked up bc I'm bypassing the main system. Thoughts? @Rhinebeck01
jellis4148
Missouri
That’s my thoughts. I’m, by no means, an electrical genius, but it should work. Im going to wire up my rear locker to one of my switches when my Jeep comes in.
