Electric Hydraulic Power Steering (EHPS) software
Nukem
Ray
Cheyenne, WY
2018 Jeep JL Rubicon
Just for everyone's edification. Went to to dealership to ensure that after the gearbox change that they updated the software per the TBS. They claim that they had but there was a new update available. I told them to update. They wanted over a $100 to update. I asked what was the difference in the software and they told me it corrected much of the steering that the older one should have. So, I told the manager, you want me to pay over $100.00 for something that Jeep should have fixed in the previous software? Got it free.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I had the cast iron steering box and updates put in about a year ago
Do you have the TBS number or any info on it
I would like to Know if mine has the latest update
My problem from day one was the surging when turning and low speed
Thanks
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
My CI replacement did not remove the quirky steering of the electric PS, however, the dealer adjusted toe in almost to an extreme, making it tiring to drive while constantly correcting it. How is yours doing now with the new software update?
Nukem
Nukem
Ray
Cheyenne, WY
Thanks
The dealer can tell you. I didn't get a new number.
Nukem
Nukem
Ray
Cheyenne, WY
Slightly better than before. Once the fluid heats up, it drives better.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I have a lot of upgrades to the front end put the biggest difference is when I installed the steer smart sector shaft brace
It eliminated all the play and wondering in the steering
Put you also have to ether have at least 1in. bump stops or use the Synergy track bar that has been bent to clear a sector shaft brace
The factory and others will hit the bearing support on the sector brace when the front right suspension is completely compressed without one of the two upgrades
I highly recommend a sector shaft brace
Tank2112
Darryl
FL
2023 Wrangler 392XR, Custom Jeep LJ
May want to have caster angle checked.
Bayrat
DA
NY and Fl
I did, when I traded on the 392 :CWL: The entire reason I had the switch done, was for a new owner once I traded, and I knew the warranty would be expired. Hopefully that same dealer finished what they started with it.
