Electric side step power source question
gregoryd3
Greg
Charlotte
2018 Sahara
I’ve searched and not found anything. i’m going to install some power steps. Any reason I can’t power them off an aux switch So I can turn them off and on? i’d rather not have the secondary switch most come with.
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
For the RSE steps the switch appears to be an 'enable/disable' switch rather than an actual power switch. Removing power to the steps (by pulling the fuse) results in a full reset of each step's controller and respective self-test / calibration cycles. That is different than just using the provided switch.
I don't see any reason you couldn't power the steps from an Aux switch (1 or 2 for the higher current limit), however you would still need to use or modify the existing switch wiring to 'enable' the steps.
Regarding the Aux switches, although I use the 'remember last setting' function they occasionally fail to remember and return to the 'off' state. If yours do that too it might be a source of frustration by sometimes causing your steps not to deploy.
LF
jjmarkus
Jay
Cibolo, TX
2021 JLUR to replace 2018 JLUR, 2020 GMC Sierra, 2019 Subaru Crosstrek, 2007 Shelby GT500
The one reason not too is that if you let your Jeep sit for a few days the battery will drain slightly and disable the accessory switches until it's charged back by driving it. I originally connected my amp research power steps to an accessory switch but later went direct to the battery because after a few days of setting my steps would not operate (accessory switches disabled) until the battery was charged back by driving it. It was just a hassle to deal with.
