E85 issues in 2022 3.6L etorque
Frank R.
NEPA
2018 JLUS
What, exactly, made this seem like a good idea?
Frank R.
NEPA
2018 JLUS
Tried to save money, thought it was a flex fuel vehicle. Haven't you ever made a mistake in your life?
I bought generic ketchup once, does that count?
But taking the chance of blowing up a brand new $55kish vehicle to save $3 on a tank of gas - that's a whole other Oprah...
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
I personally think it's best to run the lowest level of ethanol possible (unless you're specifically running an E85-tuned vehicle), but you could try the cheaper E15 (Unleaded 88) since that's approved, if you have it in your region.
Right now it's only 30¢ cheaper per gallon versus Regular 87, but over the summer it was almost $1/gallon cheaper. It'll likely get you much worse fuel economy, so unless it's a big difference in savings it's probably still best to stay with 87 and keep a light foot.
LooselyHeldPlans
Brandon
SW Colorado
2020 3.6 JLUR
Several
I decided to try a tank of windshield washer fluid in my 2020JL yesterday…
jeep1941
2023 JLUR 2.0T Firecracker Red
I decided to try a tank of E85 in my 2022 JL HA yesterday and discovered immediate results. Within 5 miles discovered the power loss, shifting issues, and now the CEL is on and start/stop is unavailable. My shift points are all over the place, and it doesn't want to shift out of 6th gear at highway speeds. Fuel economy is down almost 25%. Has anyone had these issues before and if so what's the correction method? Dealer said they'll run codes but are a month away from service appointments. Will this correct itself after using the fuel and running back on 87 or 89? TIA
Sorry to hear you’re having issues. If I were you I would honestly siphon the tank if possible. If not I’d drive it until maybe half a tank in one go and dilute it with regular gas. Not good for the engine/fuel system overall to run E85 since it’s not designed for it but for a one off thing it’ll be fine. Lesson learned!
jeep1941
If you're looking to further expand your cost-savings, DOT3 brake fluid is an extremely budget-friendly alternative to high end automotive detailing products - give it a try.
I usually use it on my door hinges to combat the bubbling issue I read about.
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
DON’T drive it another mile…pump the tank and add back non ethanol fuel. If a trip to the dealer is required your warranty will be toast. Good luck with your outcome…hopefully the CEL will clear on its own though the error code will be stored for a while and therefore discoverable by a dealer. Others probably know more than I about how long error codes are retained.
