- Oct 12, 2016
- Westchester, NY
- JLU Sahara
- Banned
- #46
Thanks for your input. Watch this video from Brandon Halon of Youtube's Jeep Informant, This shows that all those terminals except N1 are connected to main battery through fused connections. Basically, N2 - N8 connect to the same power distributing piece of metal. And read the label on the underside of the PDC, it labels what terminals N1 - N8 connect to. Your jumper to N5 is electrically connected to the main battery on N2. It should go to N1 to connect to the Aux battery. Reread Rusty Teeth's posts #31 and #42, I believe he confirmed N1 - Aux and N2 - Main based on his voltage measurements at those points with depleted and charged batteries. Feel free to point out any flaws in this post.
Edited to add reference to #42
I hear you Jebiruph and will investigate this carefully. But let my pose my concern this way. In the Brandon Halon video I cited he claimed the wire off of T5 (N5 if you prefer) lead directly to the positive side of the ESS battery.
Was this wrong, or was it right and I am just missing a point you're making? (PSS: nevermind, I see above where you suspect that T5 doesn't go to the ESS battery.)
I'm going to reread Rusty Teeth's stuff like you said, and I fully believe you when you say I probably should be on N1, not N5.
I've seen this video. I probably just didn't take away from it the facts you did.
Thanks.
