Doors wont lock
JoeSchroe
MA
2015 Wrangler Unlimited
Just took delivery of my JLUR yesterday, and today realized that my doors wont lock via the key fob or the buttons on the door, only manually on rocker or with the key in the keyhole.
It will be a few days before I can make an appointment to let it sit at the shop, but wanted to throw it up on here and see if anyone else had experienced it and if there might be an easy fix, like a fuse, or something.
BillG
Middle Tennessee
2018 Sting Gray JLUR / 15 Harley Tri glide / 50 Dodge Rat pickup
Well since both of those scenarios involved the power locks, I’d check that fuse.
EJ3CTA
Steven
Painted Post, NY
2018 Jeep Wrangler Sahara
Can you roll the windows up and down? The electrical connectors may be loose.
Sean L
Sean
North Carolina
yes, check the fuse and relay, then check the door electrical connections. Either way this is a Warranty issue.
JoeSchroe
MA
Certainly on my list to check... oddly enough, the tailgate locks and unlocks fine. It's that in its own power locks fuse?
JoeSchroe
MA
Windows and power mirrors both work.
BillG
Middle Tennessee
Not sure about that. Might have to check the users guide or owners manual.
Sean L
Sean
North Carolina
Its more likely the connections to the doors themselves then.
maguro
Ken
Canadian Rockies
Punk'n JLUR
Wow. You'd think the dealer would've noticed while they were preparing your vehicle.
JoeSchroe
MA
Not the fuse, gonna check the wiring harness on each door but with windows working and tailgate locking, I doubt it's that. Looks like I'll be taking it back to the dealership...
Penukoko
Draper, UT
Not sure if you figured it out or not but I found that one of my key fobs only unlocks by pressing lock. The other works fine. I thought it was the Jeep but I need to take the key fob in for replacement or repair.
Penukoko
Draper, UT
In other words, I thought the Jeep wouldn’t lock, but it was because my key fob either has a low battery or doesn’t work correctly. Try your other fob.
JoeSchroe
MA
It was actually the door latch mechanism. It wasn't recognizing the door as closed, so it wouldn't lock.
Got it back yesterday fixed, but now the left rear light is out
grady2hig
Wisconsin
2018 Rubicon JLU, 2017 Toyota Sienna XLE 4WD
Maybe one of the doors isn't close all the way...
