Doors Off Hanger - Help
JEEPCINEMA
Cinema
2024 2-Door Sport
Hello All,
I purchased an inexpensive door hanger for my 2024 2-door and I have run into an issue. Probably, my own fault, but I’m so used to the older Wranglers.
The hanger - https://www.quadratec.com/p/body-ar...e=1&gbraid=0AAAAAD_wpjh22n3gB7OPYMA8vu-vOfjcU
The issue, these two door stops or whatever they are (Photos attached) are not my jeep. Grabbed them from the web. But they are what’s causing the issue on my doors. The photos are also a different holder.
They get in the way and I can’t close both doors all the way when the inside of the doors are facing the wall. Is it as simple as turning the doors around? Of course I didn’t try. All the pictures show them with the outside of the door facing out. If I turn them, I loose the door latch to keep them closed.
Thanks for the help.
Jeep Wrangler JL Doors Off Hanger - Help IMG_1724
Jeep Wrangler JL Doors Off Hanger - Help IMG_1725
melendez69
Marc
Waxhaw NC
...huh?
If you can't get them to swing flush to the wall, why not bolt up a 2 x 4?
Als@Ohio
Al
Northern Ohio
97, 15, 18 Wranglers
Hello All,
You can just push them into the door. It might be helpful to put loop of paracord through the bolt hole to pull them back for when you put the doors back on
siggy
Kansas City, MO
Fun ones!
I have the door hanger you linked. Are you saying the door stops are in the way? That’s what happens to me with the particular hanger you linked. It would’ve been better if they staggered the mounts. For some reason all hangers like this are designed the same way. The door stops interfere with each other if you remove the doors fully open. If you close them one click then your issue is solved. You can push the door stopper in one click with the doors off, but it can be a bit tricky. Easiest is to put the doors back on the Jeep, close the door one click, and then remove doors.
JEEPCINEMA
Cinema
2024 2-Door Sport
Ok. I will try this. I didn’t even think to close the doors. Thank you!
73TAWM
Troy
Missouri
21 JLU RUBICON 2.0T 3"LIFT 37's
Lumber Sales
That ^^ is for anyone wanting door hangers for dirt cheap that work flawlessly. Just ask me ;)
As for your problem you need to let those pop back into the door. They can be a bear to pull back out. I use a screwdriver and put it through the hole while my wife holds the door and I pull the dickens out of it until it pops back out.
siggy
Kansas City, MO
Fun ones!
You don’t need to push them all the way into the door. When you remove the doors you unscrew the door stopper when the door is one notch in from all the way open.
73TAWM
Troy
Missouri
Lumber Sales
I have tried it halfway and it does work. But, if I push them in all the way the doors lay completely flat against the wall. Keep in mind that I am referencing what happens with my self made hangers, so it could vary depending but I assume they all fit the same if they are hanging from the door studs.
siggy
Kansas City, MO
Fun ones!
Ah gotcha. Depends on the hanger design. I can speak directly to the link the OP posted. I know the OP doesn’t have those, but if they’re a similar design (there are several competitors), then OP just needs to have the stopper go in one detent and that’ll work. Personally I wouldn’t want the door skin against the wall, but I could see an argument the other way. I’m just a diva with my garage appearance and prefer the door skin showing 😁
73TAWM
Troy
Missouri
Lumber Sales
With mine you can hang the door either side. It's just if I leave the stops halfway out the doors will stick out at an angle and get in the way of other things going on in the shop. Nothing actually touches the wall. it's a great design for around $10.
JEEPCINEMA
Cinema
2024 2-Door Sport
That was it. Thank you!
