Door seal bad?
mrjakecyrus
Jake
Minnesota
2019 Black Sahara
I can notice quite a bit of wind/breeze coming from my drivers side door near the latch. Think I just need to add some foam stripping? Or is this a seal problem?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Does door look lined up? Otherwise, check seals and adjust from there. If it's that's noticable though, I would get the dealer to look while it's under warranty. If you try to "fix" it, they may decide to not cover you.
jludave
The Isle of Long
IT Manager
Bad/incorrectly installed door seals do happen from the factory. I had one on my driver door on that caused a leak when it rained. Took it to my dealer and their leak specialist found the issue and the seal was replaced under warranty.
j2.pictures
Justin Null
Northern California
www.instagram.com
2021 Wrangler Unlimited Sport S
CDJR Salesperson
I do not experience any additional wind noise, but my door did leak when it rained. I ended up fixing it by lining the stripping back up
Ajk
Alex
Buffalo, NY
2019 JLU Sport
I have the same problem. I had the dealership replace the driver and passenger side weatherstripping under warranty last winter and it was much better...until 4 days later when I pried my door open because it was frozen shut in the 10 degree weather. Now I know to lube my seals with 303 but I have to get them replaced again first. They were on back order for 5 months and I was so frustrated when they went bad again that I've just been dealing with the wind noise lol
