Door hinge issue - different sizes top vs bottom?
boontis
Kevin
Calgary, AB Canada
2020 Wrangler Sahara Unlimited 2.0L
I just had doors off for the first time this week, and I decided to replace the hinge bushings. I ordered a kit on Amazon that had hundreds of good reviews - plastic instead of the factory aluminium.
Aside from having to hit the old ones with PB blaster and letting it sit overnight before hammering the hell out of them - the job was straightforward and relatively easy.
That was until I went to put the bolts back on the front door hinges. (Backs went on perfect) The bottoms went on easy peasy but the first top one felt tight - it wasn’t cross threaded as I stopped and checked - but after a couple turns it twisted off the stud!?! When I moved to the other front door it was the same thing - bottom easy top felt super tight. I stopped and left it off as I didn’t want to twist the stud off again.
Two questions for the group:
1 - has anyone else experienced this? Did I do something wrong?
2 - any major issues with just leaving the bolts off the top hinge?
Thanks in advance!
