Does your freedom panel bag look like this?
Ron93YJ
Ron
Pittsburgh, PA
2021 Rubicon 4xe
I noticed my freedom panel bag seems to be defective unless I’m just not understanding how it works. It looks like I’ve got a foam piece in the groove where one of my panels is supposed to go. Am I missing something here?
Jeep Wrangler JL Does your freedom panel bag look like this? IMG_3346
Terrymo
Terry
2023 JLURXR 3.6 ET
Here’s mine and a quick video from @Northridge4x4
Jeep Wrangler JL Does your freedom panel bag look like this? IMG_2153
Jeep Wrangler JL Does your freedom panel bag look like this? IMG_2152
Jeep Wrangler JL Does your freedom panel bag look like this? IMG_2151
Ron93YJ
Ron93YJ
Ron
Pittsburgh, PA
2021 Rubicon 4xe
Thanks. Still doesn’t make sense why there’s a piece of foam there. It seems like it would fit much better if the slots were both the same
Crum44
Point Pleasant NJ
Ordering 2022 Willys
Stopped using freedom panel bag, as zipper on bag was all screwed up. Just set panels in garage on towel at this point. Might see if zipper can be repaired
Obviousbicycleco
Zach
Minnesota
2018 Jeep Sahara JL
Mine looks the same. However, it seems that the foam is too thick in those spots and would be better if slightly shaved down. The zipper on it is far too snug because to me, they sit too high. If I were a betting man, I’d say the engineer said it worked perfectly in a CAD program, but in the real world, it sucks.
I only use the bag now to set my panels on it in the corner of the garage when I take everything off.
Sardaukar
Wisconsin
2023 JLUR 6MT, 2023 JT Sport S
Software
At least you have foam inserts. Our Gladiator came with a cheap bag I think the dealer bought off Amazon. We even showed them the bag that came with my Wrangler (from a different dealer). We eventually gave up arguing with them. We were less motivated to fight for it in the middle of winter.
MeefZah
Lexington, Ohio
2020 GX460
Mine looks like that but it works fine, zipper is fine and roomy. I actually find the bag useful. It is a little convoluted how the panels are supposed to store but if you look closely at the diagram they indicate orientation and which one goes where.
2024-JLUR-X
Orlando, FL
2024 JLUR-X with Extreme 35 package
Mine looks the same. You just need to make sure you are following instructions and it will work with out a problem.
The zipper can be a little tight if not fully inserted.
Good luck!
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Freedom panels, on the 4th of July. 'Merica!
KCSgtMaj
Andy
KC
MY24 Rubicon Unlimited, 3.6L
Retired Marine, Master Plumber
Follow the simple cartoon printed instructions. Easy peasy.
NPC 20883467
Over the Divide
'20 JL Sport S, '97 TJ Sport
Same here. Falls into the category of "I don't have time for this shit."
