Do you believe 37s will fit without modification?
pnut
M
Michigan
2022 Wrangler 392 XR
With a 2" lift on a "normal" Rubicon, you can fit 37's. From what I have read, the 392, has the 2" lift on it already, which means 37s should fit right out of the box, right?
Anyone else planning to put 37s on right away?
BCMgunner
Eli
392 on 37” KO2s
Depends on the backspacing of the stock rims.
And you’ll need the aftermarket Mopar tire carrier kit to accommodate the 37” spare.
And you’ll need to remove some plastic from the rear wheel well and do some heat gun work if you’re planning on full flexing (or add a bump stop in the rear).
Rosco P
Charlotte, NC
Jeepless at the moment.
Backspacing looks stock. Planning wheels and 37 km2 or Goodyear Kevlar. As soon as I get an idea of arrival, I’ll get them on the way.
danm
Philadelphia
2020 Jeep Wrangler Rubicon 2-Door Sting Gray
Another user figured out that BFG is coming out with C rated 37’s (for the eh hem, Raptor) Might want to look into a set of those.
pnut
pnut
M
Michigan
I heard the same but they were AT’s which seem too tame.
pnut
pnut
M
Michigan
In my case not stock wheels but aftermarket. The stickers just aren’t wide enough and have too much backspace for 37s from what I’ve seen.
