Come on...it's a 392! You know there won't be much fuel left in the tank for anyone to steal anyways.I heard that the 392 outer fuel door might be a slightly different size than other JL's? Is that true? If so the standard locking JL gas doors will not fit properly. Anyone had any luck fitting a locking fuel door?
Very easy install....fits perfectly....I heard that the 392 outer fuel door might be a slightly different size than other JL's? Is that true? If so the standard locking JL gas doors will not fit properly. Anyone had any luck fitting a locking fuel door?
That's crazy. Why wouldn't the button be near the rear of the Jeep, near the fuel inlet?I believe the 4xe has a gas cap that opens via a button below the headlight. I'd love to see this adapted to other models.
You press it as you get out of the jeep. The fuel tank needs 10 seconds to depressurize before filling anyway.That's crazy. Why wouldn't the button be near the rear of the Jeep, near the fuel inlet?
Oh, that post said it was under the headlight, I envisioned it UNDER THE HEADLIGHT. He must've meant under the headlight switch.You press it as you get out of the jeep. The fuel tank needs 10 seconds to depressurize before filling anyway.
Haha, yes, under the headlight switchOh, that post said it was under the headlight, I envisioned it UNDER THE HEADLIGHT. He must've meant under the headlight switch.
LOL. Yes, under the switchHaha, yes, under the headlight switch
