alksion
Great looking tire2” Aev spacer lift on 37s with a livernois performance tune!
Looking great! I believe we are moving to set of 392XR wheels over the winter (part not yet orderable) but should be same specs as your Mopar beadlocks. Did you need to run a wheel spacer at all?2” Aev spacer lift on 37s with a livernois performance tune!
Looks awesome! no spacers for mine.Looking great! I believe we are moving to set of 392XR wheels over the winter (part not yet orderable) but should be same specs as your Mopar beadlocks. Did you need to run a wheel spacer at all?
Here's our work in process... 2.5 lift, zeon platinum synth, 37's, rock slider steps (not picture) and the ever important fold-down picnic table.
Looks AWESOME Brian!Looking great! I believe we are moving to set of 392XR wheels over the winter (part not yet orderable) but should be same specs as your Mopar beadlocks. Did you need to run a wheel spacer at all?
Any more photos of this, I'd love to see more. Trying to decide between clear or stealth myself!Xpel Stealth PPF with Ceramic Coat on top. Stereo next, then wheels and suspension.
Hi Sam. I recently bought 392 xtreme recon and looking for hood lights. Love your setup. What lights and brackets did you install. Thanks.On to another positive post. Sorry for my post above.
Today’s adventure.
Threw the Bestop sunrider I had on and took it to the hills again. Really is a fun ride.
Sam
THANK YOU!! Ordering now.Baja Design LP4s. Don't know what brackets. Just one off Amazon.
Sam
I would add some skid plates, I would of left my engine oil drain plug, exhaust crossover pipe along with my muffler at Moab my first time out.Getting back to the main topic, here is what I am planning for my 392 XR:
Installed:
37" Cooper STT Pro tires
Warn 12k winch
ARB Twin air compressor
RSE step sliders
Maximus 3 stinger hoop
Purchased and received:
Metal Cloak 2.5" Game Changer suspension lift
Baja Designs LP6 and LP4 lights
Purchased and waiting for parts:
Accu Tune Fox 2.5 DSC adjustable shocks
Next Venture differential covers, differential skids, lower control arms skids.
And that should pretty much wrap it up.
I have the cast aluminum pan. I installed the Fumoto F106N FN-Series Drain Valve with Long Nipple with Lever Clip. Then I just attached a rubber hose and it makes oil changes easy. You will also need a new front driveshaft with the MetalCloak Game Changer lift.Which oil pain do you have, cast aluminum or stamped steel? And how are the oil changes with those skid plates? Does the oil run out cleanly, or does it get all over the top of the skid plates?
