DIY Ammo Can Taillgate Storage.
Saejin
Gene
Colorado Springs
JLUR - Firecracker Red
Hopefully, one day, FCA will release the trail rail management system so we can utilize more options to add storage. What I’m seeing here is the use of the already existing mounting points for the trail rail that goes on the tailgate.
I’ve thought about mounting something similar (modular rails) using the existing tailgate and floor mounting points.
JD Flick
JD
Redondo Beach, California
Algorithmic Trading Strategies
Really good idea, thank you for this thread.
I run my Jeep topless and doorless full-time, and have been looking to solve the storage problem.
I ordered a Smittybilt rear storage lockbox:
http://www.smittybiltdepot.com/Smit...63.aspx?t_c=67&t_s=414&t_pt=3847&t_pn=S/B2763
Your solution is elegant and has advantages though.
- Lighter weight.
- More trunk space available.
- Retains access to the under-floor and jack storage areas.
If things don't work out with the box, I'll definitely give it a try.
HiJinx69
HiJinx69
Richmond, VA
2018 Wrangler Sahara Unlimited JL, 2014 Mazda 6, 2010 Honda Odyssey, Yamaha FZ-09
Here is more info on the setup.
Ammo can dimensions: 5.5W x 7hH x 11L inches
The dimension from edge of ammo can to back of rear seat is 25 inches
The cans can be opened from the inside, so locks are needed to deter sticky fingers.
The freedom panels will not fit flat with the rear seats up. You can use the bag hooked up to the back of the rear seats standing up as instructed on the bag. Or, you can otherwise fold down rear seats and lay it flat.
Hope this answers most of the questions.
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5451
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5454
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5455
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5456
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5458
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5459
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5460
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5461
Bolts used: M6-1.0 x 30MM
Creative use of shims/spacers to clear the edge of plastic panel.
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5468
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5473
Bonus! I used small neodymium magnets (STRONG!) to keep handle and lock from rattling around.
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5463
Jeep Wrangler JL DIY Ammo Can Taillgate Storage. IMG_5464
One last thing to note. The locking hardware does not come with ammo cans. I got them through Amazon, probably on eBay as well. You will have to drill a hole to attach them.
Happy DIY'ng!
prw04
Paul
North Carolina
2019 JLU Rubicon Billet Silver
Ay chance you remember the size of the hardware used to on three hole of the tailgate? Been trying to ID them. Thanks
ToolMan514
Tim
Montréal, Québec, Canada
'22 Rubicon 4xe
Thank you! Your response is most excellent and very exciting! I wasn't sure about the wing nuts holding the cans on, but it makes sense if every you need the few extra inches in a pinch. Did you consider drain holes in the bottom in case some water gets in?
HiJinx69
HiJinx69
Richmond, VA
No holes needed! Most ammo cans have a rubber seal on the lids.
HiJinx69
HiJinx69
Richmond, VA
Don't know off hand. I will check on that, perhaps tomorrow and will let you know.
prw04
Paul
North Carolina
Dubeau9005
Keith
Ottawa
2018 Jeep Wrangler JLU Sport S, 2010 GMC Sierra 1500
One last thing to note. The locking hardware does not come with ammo cans. I got them through Amazon, probably on eBay as well. You will have to drill a hole to attach them. Happy DIY'ng!
Thanks. Absolutely appreciate all the info. After seeing your pics with the tailgate close, my idea of having the latches tight up against the sides when tailgate is closed definitely won’t work now I that I can see the layout of it. This post has been so helpful. Great job!
macintux
Indianapolis, IN
2005 LJR, 2022 JLR
Very nice. I have the Bestop instatrunk, which is very handy, but during the winter I really miss having an easy way to access the storage area back there (my soft top rear window isn't much fun to wrangle). This might be a nice replacement.
HiJinx69
HiJinx69
Richmond, VA
I updated my post with info on hardware/bolts used.
prw04
Paul
North Carolina
@HiJinx69 thanks for all the follow ups. Greatly appreciated.
