Display screen replacement?
Jguru23
Josh
Northeast
Sahara Unlimited
I have a Sahara with the upgraded display size. It appears my young nephew rubbed something across the screen causing damage to the screen. Is this something easily replaced by a dealer?
Jeep Wrangler JL Display screen replacement? IMG_6769
Jguru23
Josh
Northeast
Sahara Unlimited
Excuse my ignorance..."head swap"? Sound expensive as hell already.
Jtclayton612
Memphis, Tn
2020 JLU Sport S
Head swap means swapping the entire head unit out. So the screen, radio parts it’s attached to, and all the various systems it has to handle its inputs gets replaced.
if I remember the last time I was looking at them they were in the ~$800 for parts and then labor if you have someone install it.
maybe the dealer can just swap the screens.
rohdawg
Long Island, New York
Merchant Marine
BOAMED 8.4" Touch Screen for 8.4" Uconnect Radio Screen Navigation Digitizer Without LCD, New OEM Replacement Touch Screen Fit RAM 1500 2500 3500 Dodge Jeep Chrysler 2017-2022 https://a.co/d/0I2H9ni
Jeep Wrangler JL Display screen replacement? IMG_6213
Spank
If you're somewhat comfortable with electronics, the screen isn't actually too difficult to replace. It is expensive, though. I believe the part you're looking for is LA084X01 and it can cost between $350 and $500. OEM (from LG) is more expensive, obviously. I'm not familiar with alternative brands, but a replacement screen is a hell of a lot cheaper than an entire radio.
You'll have to remove the unit and disassemble it, then remove the screen from the frame that surrounds it by slightly bending out metal tabs that secure it. It sounds daunting, but it really isn't that bad. Everything is plug and play and requires no special programming. You're just dealing with ribbon cables, mostly.
Sometime after 2020, LG changed the screens to address the delamination issue, but it comes at the cost of the actual quality of the screen. The older ones had very little backlight bleed where the newer ones are much more prominent. I'd avoid getting a used screen from a radio older than 2020 as the heat that pumps out of these things are what separate the various layers.
In the future, don't use anything but water to clean the screen. No chemicals, no special cleaners, just water on a fresh microfiber towel.
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
ive replaced just the screen, on a dodge charger, Durango and a couple of other Chrysler cars at my shop, if you drop me a note with the VIN , i can verify it for you if its available , and its easy to do if so
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
Maybe find a non working head unit with a good screen and swap some parts around.
Jguru23
Josh
Northeast
Sahara Unlimited
Rohdawg...are you suggesting I can purchase that simple $35 item, open the dash, and just replace that screen?
Certainly a better scenario that the $800 someone suggested.
Thoughts?
TorturedMargot
US
Shouldn’t the parents of the nephew be paying for the damages? I say take it to the dealer and get your radio back to the way it was.
Rustydog
Palm Desert & Big Bear Lake, Ca
2019 JLU
Thoughts?
You would need to pull the head unit. Im sure there is a youtube video on how to get it out. looks easy. I bet the screen placement isn't too difficult with that amazon part. don't have a lot to lose.could be fun.
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
Thoughts?
I believe the digitizer is glued to the LCD and it has to be carefully removed from the LCD and attached to the existing LCD. Folks are using these to fix 8.4" head units which the digitizer is delaminating from the LCD panel.
