Disable ignition chime
stick
NC
2018 JLU Rubicon, 2024 JLU Willys 4xe
So has anyone figured out how to disable the ignition or accessory chime that goes off constantly when the drivers door is open and it’s in either ACC or RUN?
I get I can run down my battery but I do actually like to open the doors and listen to the radio when I’m working on or cleaning the JL and the engine isn’t on.
Back when it had an actual key you could put it in run but with push to start this no longer works.
BillG
Middle Tennessee
2018 Sting Gray JLUR / 15 Harley Tri glide / 50 Dodge Rat pickup
Have you tried unplugging the door on the occasions that you want it open with the radio on? Might work.
RMojitoJL
Skyler
Las Vegas, NV
2019 Jeep Wrangler JL Rubicon *Mojito*, 2019 Jeep Grand Cherokee Altitude, 2019 Honda Civic Hatchback Sport
Loan Officer
Roll the windows down and close the door ;)
jeepixel
Al
TX
WBGO View, 2019 2d Wrangler Rubicon
I copied this from a previous post, so I hope it helps. . .
Get in and put the seat belt on. Turn the Jeep on, but don't start it (acc mode), the diagnostic screen will briefly show the seatbelt warning indicator. As soon the the indicator goes away, quickly disconnect then reconnect the seatbelt 3x. Turn off the Jeep. You'll still get warnings on the dash, but this will disable the chime. To re-enable, repeat the process.
YMMV. . . good luck and be safe!
RMojitoJL
Skyler
Las Vegas, NV
Loan Officer
Ormond Beach, Florida
Retired at 55 ..
I’m thinking this might disable auto park as well
I have a seat belt clip in the mail on the way to me. Cost me $1.49 .
I will tell you / post here in a couple of days if it disables auto park.
Jeep Wrangler JL Disable ignition chime s-l500
RMojitoJL
Skyler
Las Vegas, NV
Loan Officer
I use these, or a similar style but obviously same concept... and auto park isn't an issue for me.
Retired at 55 ..
TahoeJeep
DJ
Livermore
2019 Wrangler JLU Rubicon
This should work
Try this....Here’s a video I posted onto YouTube
Retired at 55 ..
@TahoeJeep
I was already aware of, the way you are temporarily disabling the chime..
I have done this when working on someone else's vehicle. I can see say a tech in the dealership or local shop doing this simple approach to stopping the chime.
For an owner though.. the guy/gal that owns the JL.... my feeling is just disable the chime altogether.
This disabling which is easily reversible, can be done simply with a programmer or a enable/disable sequence.
Disable the chime ..... and be done with it forever more so to speak.
Myjeep
Patti
Idaho
2018JL Sahara
Isn’t that just like plugging the seatbelt in behind you?
Retired at 55 ..
@Myjeep
YES, it is exactly the same.
Except with the seat belt clip, you are not sitting on a friggin buckle.
Also when you drive off, you don't have to get the belt from behind you, you just pop out the seat belt clip and fasten your seat belt.
