Cutting out Bumpstop extension?
Occam'sRazor
New Mexico
2018 Mojito JLUR, 2023 Reign JLUXR, 2023 Earl JL
I have a 2" bumpstop extension in the front of my JLUR. I want to swap this for an 1 1/4 to gain some up travel. I don't want to disassemble and remove the springs to do this. I'm sure I can get the new ones in but I'm tempted to cut out the old ones - sawzall? Has anyone done this?
Zandcwhite
Zach
Patterson, ca
2019 jlur
Sure it's possible, but don't be surprised if it turns into more work than just popping the bottom of the spring out. Cutting things that aren't secured with a Sawzall doesn't work well. Even if you start cutting while it's bolted in, once you get past the center you're trying to reach inside the spring and hold it while you cut.
Occam'sRazor
Occam'sRazor
New Mexico
I understand. I've run this around in my head for a while. Thought about going from both sides to the center, from the top (if I can fit a blade) and slicing into 3 pieces with the center still bolted. but ultimately your probably correct and I'm fighting it at some point. That's why I thought I'd see if anyone else has attempted this.
Terrymo
Terry
2023 JLURXR 3.6 ET
Just to clarify, are talking about the front bump stop and shortening the front metal jounce tube
Jeep Wrangler JL Cutting out Bumpstop extension? IMG_2165
Occam'sRazor
Occam'sRazor
New Mexico
No, I'm asking about the 2" UHMW bump stop extension (added with lift) that is sitting on top of the front axle. Bottom of spring.
Occam'sRazor
Occam'sRazor
New Mexico
I personally wouldn’t do it that way, but then again, it only takes me about 5 minutes to pull my springs….
Sorry but I'm not that fast. Takes me about 5 min just to get up off the concrete garage floor!
Roky
Roky
Yeah , I get it, I didn’t say it doesn’t hurt, lol…. It just seems easier , even if it takes a little longer, to clean up the cut if needed and paint the raw edge, things like that…..
Occam'sRazor
Occam'sRazor
New Mexico
Just to be clear, I'm not talking about cutting down the existing bumpstops, just obliterating them into small enough pieces to remove so I can slide in the new smaller ones at full droop without disconnecting anything.
ArmyRN
Paul
Longview, WA
1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
I wish someone made a sleeve with the ability to keep the factory foam bumpstop.
So you pull the foam bumpstop, cut the factory jounce tube 1.375" measured from the bottom of the jounce tube (is that how much longer they are on the XR models?), slide the jounce tube sleeve over the factory piece, and then pop the foam bumpstop back in place. I'd buy it in a heartbeat.
An ACOS from JKS would work, but at a minimum you automatically get a 1" lift.
Terrymo
Terry
2023 JLURXR 3.6 ET
Me too. I thought about shortening the tube. I can cut but not weld so that’s a no go. I looked into the ACOS and similar options but they are too much for my budget.
gato
New England
2021 JLUR
If you are dead set about not removing the springs, I'd let it droop and use combination of dramel (circular cutting wheel) and drills to to split the bump stop top to bottom and punch it out. Remove the bolt, then put a 1" hockey puck on other short bump stop in. You can even RTV the puck in there.
I know it sounds kludgy, but you can certainly obliterate that bump stop extension.
You can also use a spring compressor.
In the end though, I still think it's easier to remove shock bolt, remove sway bar bolt, droop it and pull the spring. You can even mildly use a spring compressor if you don't want to disconnect everything.
Occam'sRazor
Occam'sRazor
New Mexico
Thanks, those are all really great ideas. Drill especially, and I'll have to look at my dremell. Spring compressor might also be very nice.
Zandcwhite
Zach
Patterson, ca
2019 jlur
I considered using hydraulic bump stops up front in order to shorten the front tube, but then we went to 39s and 3.5" lift springs and had to add an extra 1" of bumpstop for clearance. A stock xr needs shorter tubes or at least a 1" lift. I think Jeep built them that way so we could clear 37s without adding any bump stop.
