Our radio is cutting in and out and its not searching for the sat signal. Anyone experienced this issue?
Have you pulled the F97 fuse to reset the radio?I just started to get the same thing, starting this past Sunday. I noticed the back up camera didnāt work when the reception was cutting in and out aa well. I have the 8.4 inch radio. How about you?
Well crap. I read on here from a lot of others that pulling the fuse usually helps.ok pulled the fuse ,reset the radio, no difference. Still cuttingout
Does this TSB describe what you are experiencing? https://www.jlwranglerforums.com/fo...t-backup-camera-issues-etc.34506/#post-781459Our radio is cutting in and out and its not searching for the sat signal. Anyone experienced this issue?
Do you have a sky one roof?ok pulled the fuse ,reset the radio, no difference. Still cuttingout
Is the radio working normal yet? The audio cutting in and out seems to be an intermittent problem that doesnāt happen too often, but is annoying as hell when it does happen.
