NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
A little maintenance today…… took my sway bar links off and cleaned them up and give them a good WD 40 bath….. wheelin around here requires a little maintenance more often. The sand is a bitch, it’s in the water holes, in the mud, everywhere….. and it wrecks havoc…..
…..and here they are all cleaned up….I know the bars are a little beat up, I can’t keep paint on them, so I stopped trying……:facepalm: ……
Just a heads up for my brothers and sisters here in FLA if you’re running heims, keep the sand out….. ✌
Man I need to get my butt on installing mine. Been in box since I got them. Yea. not much of a wrencher here. Slap my around.
Roky
Roky
Roky
My lift wasn’t available today, so I had to throw it up on the work bench……? …..
Jeep Wrangler JL Crystal Rubi build… C81523D0-AD93-4917-A4E6-3AAAB0D47534
Had to finish up reinforcing my sliders, and making my middle body bolt accessible. Cut off the bracket…….
Jeep Wrangler JL Crystal Rubi build… 2A06AA20-AE66-4F23-81A5-AE50A56B5722
Jeep Wrangler JL Crystal Rubi build… F9617EEA-587B-46DC-9482-499FBED4A05F
Modified the bracket and reinstalled it, then welded on the support.
Jeep Wrangler JL Crystal Rubi build… A1E91C7F-0F6A-4B56-B768-C85D70083C2F
Jeep Wrangler JL Crystal Rubi build… 572B44EA-A393-408B-B86D-A2058C6FF0A4
Jeep Wrangler JL Crystal Rubi build… 788D24C6-8F75-4FCE-8905-CCFCFD2C5306
Jeep Wrangler JL Crystal Rubi build… BF75EB4E-6047-4D8C-BB5A-8D60A1BEFEA2
blnewt
New Mexico
Just ask @cosine he knows!
Gotta do what you gotta do, like your lift substitute too!
And fwiw, at least your steering stabilizer still looks shiny and almost new :)
hoag4147
Colleyville, TX
2022 JLUR XR
Love the oversized workbench lol. Great idea/mod to allow access and reinforcing step/sliders. Nice ??
Jazzicon
Jasmine
Concord, North Carolina
2021 Rubicon Extreme Recon, 2021 Toyota
Dang….and I was patti
You’re like a mad scientist ?
Roky
Roky
Roky
Thanks,……..this is my other buddy’s trailer, he helped me out with the burning, I didn’t want it to look like a 5 year old did it…..I know my limitations…….. ? I hope my lift buddy doesn’t find out I cheated on him…..?
Chocolate Thunder
Jeremy
@Chocolate Thunder , didn’t you have your gears shined up, I forget the technical term, lol, if so, was it worth doing, and do you have link where you had it done ? Thanks man…..
Indeed I did. It’s called REM isotropic finishing (don’t call it polishing!) and I had it done at GearFX Driveline in NC. Was it worth it? I hope so, but I can’t say for sure because they’re still sitting in a box in my garage instead of inside my differentials because I haven’t found anyone yet that I trust to do my gears. But they’re shiny AF, so that has to count for something! The supposed benefits are great - no hear cycling is required for initial break in, they are supposed to run cooler and smoother because of the finished surface, and supposed to have enhanced lubrication also. Shoot Sam an email or call, he was helpful.
https://www.gearfxdriveline.com/
[email protected]
704.799.0955
I figured if it’s good enough for @chevymitchell it’s good enough for me.
Jeep Wrangler JL Crystal Rubi build… 47E66CB1-83FC-4A57-91B2-BDAE9DD0BE2A
Jeep Wrangler JL Crystal Rubi build… 79FBEC86-A6E8-4904-883A-E002CC46D27D
Roky
Roky
Roky
[email protected]
704.799.0955
Thanks brother!
NewJLU2019
Curtis
Roky
Roky
Roky
Since I’m running long travel shocks with 3.5” coils, my rear springs come loose when both sides of the rear axle droops together. When I stuff one side and droop the other they stay tight. So I would only have a problem if I get airborne, not likely, lol, but it’s also a pain in my ass every time I put it on the lift for anything.
I really didn’t like the idea of putting limiting straps on or near the shocks or springs, didn’t want to have to worry about what they might be interfering with when they were folded, or bunched up at ride height. Also I didn’t want to limit my droop by an inch or so either.
Sooo…. I decided to do one limit strap in the middle or close to the middle. Since I have the truss on the rear diff that the upper control arm hooks to, I decided to weld in a bushing in one of the holes in the truss….. and there’s a threaded hole in the frame…. Not sure what it’s for….maybe they set up the frame rails for the fuel tank to go on either side…..
Ride height…….
Jeep Wrangler JL Crystal Rubi build… A3D46952-C914-44E0-A51B-8E4745D444D5
I dropped the rear wheels out two different ways and I’ve got plenty of slack both ways.
Jeep Wrangler JL Crystal Rubi build… 0DC6B355-7277-43B1-AB47-8E9BFDB55FC3
Jeep Wrangler JL Crystal Rubi build… 837023BF-0635-4D31-90C9-6B343C8455B7
Jeep Wrangler JL Crystal Rubi build… 1F3D328C-FB67-4F73-A3E1-0C8F07D454A0
Jeep Wrangler JL Crystal Rubi build… B3577182-0451-4498-91EE-238FE1E3D600
I’ll have to wait till Sunday afternoon before I can see if it works on the lift….
