Coolant leak , TSB for 2.0
QWICK
Charlotte NC
2020 jlur
Hey all so I torqued down on the two bolts as instructed by the TSB but am still losing coolant. Then I saw this elbow running into the back of the engine. More coolant gathering. Can I just replace this elbow and does anyone know the part number or size ? I see them on Amazon but I don’t know what size each end is .
Jeep Wrangler JL Coolant leak , TSB for 2.0 IMG_1429
Jeep Wrangler JL Coolant leak , TSB for 2.0 IMG_1431
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
There is probably just an o-ring under there that isn't seated or went bad. Pull that bottom clip towards the front a bit with a screw driver, that elbow should lift right out and you can inspect it.
  • Like
Reactions: PBJ
doublecs
neil
arizona
2018 jeep wrangler jl sport unlimited
agree with you on that o ring easy fix. they also leak on the fitting under the coolant reservoir.
QWICK
Charlotte NC
2020 jlur
Thanks for the replies. Taking a look this weekend. I have an assortment of o rings. Assuming generic rubber will do ?
I hope this works because I’m losing a quart of coolant or more each week.
QWICK
Charlotte NC
2020 jlur
So , that t junction hose connector was cracked. I was able to pull out the broken peices and attach it back using a hose clamp. Had to order an entire new hose just to get a replacement connector :(
Jeep Wrangler JL Coolant leak , TSB for 2.0 IMG_1435
Jeep Wrangler JL Coolant leak , TSB for 2.0 IMG_1436
Ravenbeak707
Jay
Yreka
2019 jeep jl
Did u ever find out what the part was called or a general name? Mine broke and trying to figure out where to find one. Of course no dealership near me
Bsprenger
Bryce
Arizona
2021 Jeep Wrangler sport a
Hey did you end up only replacing the T junction? Or did you have to replace the hose and everything?
rcadden
Ricky
Asheville, NC
Marketing
Bsprenger
Bryce
Arizona
thank you! I realize it’s all one part, but was wondering if I could buy it all and only replace the T fitting? Looks like replacing the whole thing is kinda pointless and extra work. If you replaced the whole part was it Farley easy looks like there is barley any room to get a hand in there.
pfm
CA
2019 JLU 2.0
Hi,
I have this exact same problem on my 2019 JLU @ 61k miles!
Sounds like others have had this problem too. Just wanted to check in see if there's any updated information. Is the fix still to replace that whole hose ? or is there is a part# for just that broken T-junction ?
Has Jeep started to offer complimentary/warranty repair for this ?
Balds.78
Bryan
New Jersey
2019 Jeep JL 2.0, 1993 Jeep YJ 4.0
Hello, I’m grateful I found this thread! 2019 JL, 2.0 Turbo same exact issue. I also just purchased the hose assembly. Thanks for the link! I was trying to identify the part number for a couple days. It is odd how the antifreeze almost calcifies. Mine looked like it burped out of that connection down to the trans and I wasn’t sure if it was a cooler line due to the appearance and viscosity of the red fluid.
yes, this appears to be common now and Jeep should do something about it.
alphawolff
california
2021 JLU
You should look into replacing your primary coolant bottle while you're in there. They love to leak as well
