Clutch took a dump.
JP18
J.P.
Columbia, SC
2018 JL Unlimited Rubicon
As an update, here's the work order/bill.
It's working as designed now. The one interesting thing... I now have more power in 6th gear when on the interstate. Either that previous clutch was burning up, or they reflashed the PCM. In any case, I'm happy now :)
JP18
Jeep Wrangler JL Clutch took a dump. IMG_20190103_101514647
JP18
J.P.
Columbia, SC
It gets better. The second clutch also took a dump 600 miles later. They once again replaced the slave cylinder. We'll see how long this one lasts.
Am I the only one to have issues with this?
JP18
DanW
JP18
I haven't heard of others. If I were them, I'd dig a little deeper. I would imagine the odds are low of two bad slave cylinders. It is possible, but not probable. I can't help but wonder if something else is contributing to their failure. I've got 16k miles on mine now and it feels the same as it was when new.
Hang in there! If the 2nd one goes belly up, I'd say it is time for an entirely new transmission, which would surely cure the problem.
JP18
J.P.
Columbia, SC
The dealer said "We've had a few others, apparently a bad batch". A little suspicious but not impossible.
Both times the slave cylinder failed when it was "colder". (just below freezing in SC, that's called cold around these parts! :) ).
Not sure how the transmission is to blame in this, unless the input shaft is out of round.
JP18
DanW
JP18
Certainly a bad batch is a possibility, but what are the odds that your new production unit came from the same batch as the replacement? I'd check serial numbers. If close, then that would make it actually a high probability. If not, then unless Jeep has data, I'd be doubtful.
JP18
J.P.
Columbia, SC
I'm quite doubtful too, needless to say. No sure what else could go wrong.
JP18
JeepCares
Auburn Hills, MI
JL
JP18
Hi JP18,
We're truly sorry to hear that you are still experiencing this. Please send us a private message if you would like any additional assistance while your dealer works on finding a potential solution. We're happy to look into this to see if there's anything we can do to help!
Lydia
Jeep Social Care Specialist
LLRubylady
Lisa
NY
was an ‘18 Rubicon Mojito! now a boring Mazda
2018 JLUR with 6-speed manual. Clutch got softer and softer, eventually wouldn't return to the normal position.
Dealer called, the slave cylinder failed. They are replacing: Flywheel, pressure plate, clutch disc, throwout bearing, pilot bushing, and of course, the slave cylinder. I'm guessing the slave cylinder contaminated the clutch with hydraulic fluid.
JP18
I’m at 2509 miles. I don’t notice it getting softer but I’ll be paying attention after hearing this. Sorry for you
intentsrig
JLU Sporticon
JP18
Hopefully that’s it and not something else causing the failure. Maybe it is a bad batch but that seems odd.
Let us know
tesla
Richmond, VA
2018 JLUR 3.6 Ocean Blue
JP18
Almost 12k miles and no issues with mine. Hope they figure this out for you soon
JP18
J.P.
Columbia, SC
300 more miles, so far so good. Last time it failed when it was "cold" (relative term in SC, but it was below freezing).
JP18
1478mxm
Northern Virginia
2018 Wrangler JL Rubicon
This morning I took the Jeep into the Dealer for an oil change and tire rotation. Thirty minutes later the service rep comes out and says the Jeep is not safe to drive due to a burning smell suspected to be the clutch. I have never had any smell of burning anything. They provide a rental and I go to the Jeep to grab some stuff and it smelled like the Jeep had been on fire. Never had any issue like that prior to dropping it off. They think it is the clutch and are doing further inspections. This thread is the closest example of my situation I can find. Jeep has 5372 miles on it and this is my third stick shift Jeep. I’ll let you know how it goes.
JP18
J.P.
Columbia, SC
And... the 3rd one goes out. Similar situation, clutch felt suspect Friday night, it was cold (-ish - this is SC) overnight and the clutch pedal stayed to the floor on Saturday morning.
JP18
intentsrig
JLU Sporticon
JP18
Well, something else is causing the issue. Obviously something isn’t right internally in that trans.
Another note, when I went to the snow and drove around wheeling for a couple hours I noticed a slight grind while shifting into reverse..went away after I came down the mountain. Maybe I was throwing it into gear too fast but I think it was due to the cold.
