Climate controls not working after battery change
longJeep
Michael
I love Jeeps
2020 Gladiator
Details: 2020 Gladiator, manual transmission, 1 owner
I just replaced the aux and main battery in my Gladiator due to the main battery finally dying and the aux was probably bad for a while as the start/stop function stopped working. Now after replacing, the climate control bank of switches does not work at all and the start/stop panel is still acting like it is not getting any power. I pulled the cables from the battery overnight and reinstalled this morning with the same issues still happening. I have driven the jeep for 15-20 minutes and the climate controls stay unresponsive. I checked the fuses/relays and all appear to be in place and working.
bjm00se
JLUR 6sp ordered 11/3/21, picked up 8/30/22
I dunno man. Kinda sounds like you didn’t get one of the PDC connections re-seated properly?
bjm00se
As an alternative unrelated thing to check, a couple of my climate control switches seem to physically stick in the “depressed” position, and when one of the switches is stuck, none of the other switches works. That would be unrelated, but something you just noticed after battery replacement?
bjm00se
Fina, thought, I clicked through on the “similar thread”below and someone had the same problem before that self cured overnight 24 hours after the battery disconnect. So maybe wait and see till tomorrow before trying anything else
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
"It's a Jeep thing."
Give it a day - it'll work again.
longJeep
Michael
I love Jeeps
2020 Gladiator
I just went through and disconnected the fuse panel and plugs to reconnect. No change.
longJeep
Michael
I love Jeeps
2020 Gladiator
After some more driving, the heat has started on the footwell but the controls have no response. It is neither set on heat or feet.
Nate88cool
Nate
NE Ohio
2023 JT Mojave, 2021 JLUR, 2016 JKU
We have the same issue every year when we park our Jeep for the winter. I disconnect both batteries from the vehicle. Takes sometimes between 24hrs and 36hrs before everything is back to normal. Don't worry as long as everything is connected and hooked up right it should come back after staying connected for a period of time.
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
That would be particularly nice if you lived in frigid weather. How ridiculous :mad:
longJeep
Michael
I love Jeeps
2020 Gladiator
After 3 day I took it to the dealership. They think the control panel is “fried”
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
I had the same thing happen. I went back and removed the PDC/fuse box to find that I bent 2 or 3 pins. I straightened them out with a pair of needle nose pliers, the carefully reassembled, and it was all good.
longJeep
Michael
I love Jeeps
2020 Gladiator
I have been trouble shooting this the only way I know how. I have replaced the climate control panel and now the control box under the dash with no changes.
None of the control panel lights up with the lights on
The only button that works is the hazard button
