Click sound when opening driver door
EB12
Elvir
St. Louis, MO
2018 Jeep Wrangler JL
Im getting a click coming from the driver door when opened more than half way. Ive had the door off maybe three times since ive owned the Jeep but since last time it seems to click once when being opened. The passenger door does not do this. Ive tried loosening and tightening the bolts.
Has anyone else experienced this and if so how did you fix it?
jrohan07
Alabama
2018 JLUR GCM 2018 JLUS Firecracker Red
When you removed your doors did you push the door position stops all the way in?
Did you reinstall the door stop bolts when you put the doors back on?
First time I took the doors off that door position stop retracted in my door at an weird angle and would make a clicking sound after I reinstalled the doors.
Put the bolt back in and opened and closed the door a few times and clicking went away.
lightsout
PNW
Tighten the door stop bolt problem should be solved, That bolt has a Tendency to loosen if not totally tight in the first place
Jay 13
Jay
Toronto
JLUR
Has anyone found a fix for this yet? Just encountered this today.
chadc880
Chad
Simpsonville, SC
2018 Jeep Wrangler
There is a big thread posted somewhere through here the problem is much more severe than it looks. The sub frame inside the door has come detached from the aluminum skin of the door itself. The only fix as of right now is they have to replace the entire door or doors and repaint
rayzjeep
Ray
Melbourne, FL
2019 Jeep Wrangler Rubicon Unlimited
Aerospace Engineer
This is what I thought and what I was afraid of. Like a weld internal to the door breaking thus creating a clicking noise as that seam rubbed together.
