Class 3 Hitch Upgrade
IntegraRC
Rob
Houston, TX
2023 JLUR
Engineer
Hi everyone,
I have a 2023 Rubicon Unlimited, factory with 33’s. I have the factory tow package, but I want to upgrade to a class 3 hitch. I’m looking to tow a trailer that’s around 3100 lbs, but I want to use a weight distributing hitch (tongue weight is nearly 350 lbs). From what I understand, the class 2 hitch I currently have isn’t rated to use a weight distributing hitch, hence the upgrade.
I see there’s a lot of class 3 hitches out there, but I can’t seem to find one that would accommodate the factory wiring plug. Does anyone know one that would work? Is there a factory class 3 hitch that I can buy, seeing how the later model years can be rated at 5000 lbs?
Thanks in advance!
Rob
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
Upgrade your axle to a 2024 on up before hitching with your class 3.
IntegraRC
IntegraRC
Rob
Houston, TX
2023 JLUR
Engineer
Thanks for the response. I’m still sticking with the same 3500 lb limit. I just want to be able to use a WDH.
LukeDagny
Central PA
2021 JLUR
What can't you use a WDH with your current set up? The last WDH I owned didn't care what hitch it was mounted.
IntegraRC
IntegraRC
Rob
Houston, TX
2023 JLUR
Engineer
A class 2 hitch is not designed for the twisting forces a WDH would generate. It has to be a class 3 or higher.
Yes, there’s nothing preventing you from installing a WDH on a class 2 hitch, but it doesn’t mean it’s physically capable of the loads.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Hi everyone,
Thanks in advance!
Rob
I put a Curt on mine. I had to get creative with the bolts and drilled a small hole for one side of the factory plug. It fits almost perfectly.
Jeep Wrangler JL Class 3 Hitch Upgrade IMG_20251009_184928466_HDR
Jeep Wrangler JL Class 3 Hitch Upgrade IMG_20251009_184948308_HDR
WXman
Central Kentucky
Look through eTrailer dot com and pay attention to how the "Class III" hitches are designed and welded. Then look at the OE factory hitch that comes on the JL Wrangler. There is zero difference in strength or construction that I can see.
Either Jeep is under-rating the factory hitch, or the aftermarket hitches are over-rated. One of the two. Because there is no difference. Actually, my factory hitch has more welds and more plates than a couple of the "Class III" hitches eTrailer sells. I don't get it........
JeepinPete
Pete
PA
'19 Mojito JLUR
Mechanical Engineer
I put the Draw-Tite unit on mine. It was the highest load capacity when I bought it a few years back, but it does not play nice with the factory socket. The Curt unit pictured above looks much easier to work around FWIW.
LukeDagny
Central PA
2021 JLUR
I think, since our Jeeps are rated for 3500#, they rate the hitch for the same amount, even though it might be made to Class III specs.
Hypothetically, if somebody made a Class V hitch for my Jeep, and I installed one, my Jeep is not automatically rated Class V.
