AndySpill
- Andy
- Oct 24, 2023
- Pittsburgh
- 2018 JL Sahara
My question here is about understanding a JL Wrangler function, not building an easier or cheaper mousetrap to commercial tech to turn ESS off.
(Disclaimer: I'm a happy owner of the JL Tazer and Jscan, neither of which I use to turn ESS off. I run ESS events, have dual factory AGM batteries and my roof rack's solar trickle charging seems to have kept me from battery issues, fingers crossed.)
Before my question: most of you are familiar with relays: switches powered by one circuit (often one of far less power draw) that when energized close or open a second circuit used to energize some electrically powered device (hereafter an electrical appliance.) "Normally closed" relays only deny power to such appliances when the relay is provided power; normally open ones when the relay is not provided power. Vehicles have a fair number of relays and they can often be configured to operate either normally closed or open.
That said, take the ESS button on the dash. I'm guessing that it's a "normally open relay, with a manual switch," that can only close a circuit and light its button's light (signaling in turn further down the line to issue CANBUS messaging to turn ESS off when its circuit is closed with the button's push) when both the engine is cranked and a owner/operator presses that ESS off button. Turn the engine off and the ESS button's circuit opens, reenabling ESS (all other conditions for it to engage notwithstanding) for the next engine crank.
I haven't yanked it to observe, but why couldn't a simple device like this timed relay close the circuit that gets closed when you press the ESS button, https://www.amazon.com/Second-Timing-Timer-Multiple-Purpose/dp/B0CTFRT2YG?th=1, this linked device itself energized by some second circuit that flows power only when the engine is cranked, configured to wait a few seconds between successful engine crank and emulating the ESS off button press?
TIA
Again, this question's about understanding, not suggesting people who want to turn ESS off automatically save a few bucks and fail to instead acquire, for example, a Smart stop device to do this with CANBUS messaging.
TIA
