NoCo_Rubi
- Bart
- Feb 10, 2021
- Fort Collins, CO
- 2021 JLUR
Did some searching on the web, and this forum, and couldn’t find anything related to this with JL’s. Did find some issues with JK’s. 2021 JLUR 3.6, 8 sp. 600 miles into ownership Jeep threw a CEL p0365 and service stop/start system on EVIC about 100 miles from home after fueling up. Jeep ran normal the rest of the way back. No rough idle, no starting issues, normal acceleration and mpg’s. Cleared the code when I got home, as it was running normally. Didn’t pop up again until this morning, now 1600 miles. Tried to remote start and nothing. Got in, fired right up and threw a CEL and service S/S on EVIC. Pulled the code and same p0365. Again, ran normally all day. I’m finding it hard to believe if a cam shaft position sensor was fouled up it would run normally. One thought I keep having, is the main battery was dead when I went to test drive it in February. Dealership swapped main battery, but unsure and doubt, they replaced the aux battery. Could a bad aux battery be causing these errors? I know that battery is responsible for running some electronics. I do plan on dropping by the dealership in the morning, but just wanted to see what all your thoughts were. Thanks!
