Catalytic Converter Relocation
DaltonGang
Doesn't Play Well With Others
I don't know if thks has been discussed much, here. But, i have never liked the location of the 3.6 catalytic converters. They are up against the engine, and basically a part of headers. This makes it hard to work on things, and also produces a ton of heat, in the engine compartment, where we don't want excessive heat.
Any thoughts?
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
You could always move it down underneath before the muffler. Of course then it would be easier to steal. I can almost guarantee you that nobody is going to try to steal your catalytic converter from it current location on the 3.6l...
Old Jeeper
Don
US Army Infantry, IT Engineer
They mounted next to
Any thoughts?
They mounted it next to the engine for a purpose and that is the HEAT, helps to keep it clean internally. As it captures the particulates it will also burn them off.
Or so I was told and yes, it makes sense to me.
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
They have been doing this for many years on many makes of cars. You could just remove them. As we know, that is illegal. Plus having the cat warm up slower will just throw a check engine light due to reduced cat efficiency.
