Bump when jeep stops
JINO
Jino
Socal
2021 jlurd
When I'm braking and coming to a stop, I feel a bump right when it stops.
Went under to look for loose nuts, didn't find any.
What could be the issue.
It only happens when coming to a stop, not when braking/slowing.
swampdweller126
Tom
NY
2020 Wrangler JL
My wife had same problem on her KIA. The brake pad was shifting back and forth, changed pads no more bump.
Gangplank
Vero Beach, FL
2021 JLU Willys 3.6 eTorque w/ Mopar lift. 2022 JLU Rubicon 2.0T still stock
Is it the automatic transmission? Hard down shift?
JINO
JINO
Jino
Socal
2021 jlurd
I hope it's just the brakes!
Would there be a way to tell without removing the tire?
JINO
JINO
Jino
Socal
2021 jlurd
How good are you with a flashlight, long screwdriver and an inspection mirror? You might see it or you might not honestly.
I'll need a long screwdriver haha.
Might as well just change the pads then, recently did the front.
autotragic
the cornbelt
'21 JLR 6MT
It may not be a pad at all. Last time I had an issue like that it ended up being a bad caliper. I've had one brake pad delaminate from its backing and it made a god awful racket and you could for sure tell what was going on.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Get a friend to help you. Drive back and forth in manual first gear and stop and start repeatedly to pinpoint the noise to one wheel. Then disassemble and inspect it. Or, take all 4 apart and check torque on everything randomly until it goes away.
Or, if it’s under warranty, take it in.
Gangplank
Vero Beach, FL
I feel like I’ve read this problem before on this forum. Just sayn.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
Do you have knobby tires by chance. Might be stopping between lugs.
JINO
JINO
Jino
Socal
2021 jlurd
There's no noise when it happens.
JINO
JINO
Jino
Socal
2021 jlurd
Hold up...
What "bump" are you feeling? Do you feel it in through the seat, in the steering wheel or what? Without a noise this makes things a lot more complicated to track down.
The whole jeep.
It feels like a motor mount that went bad.
But when I had a camry with bad motor mount, the bump happened when hitting the gas or when stopping.
This only happens when I'm stopping.
autotragic
the cornbelt
'21 JLR 6MT
The whole jeep.
If it's still under warranty take it to a dealer.
