Build Sheet for Xtreme 35?
WAM
California High Desert
'05 TJ Rubicon, '25 JLU Rubicon Xtreme
Does anyone have an actual factory build sheet for a 2025 JLU Rubicon with the Xtreme 35 Package? I tried to get one for mine with a VIN search and the response came back unavailable...see Monroney. Yes there's a breakdown in the official Wrangler brochure but it hardly mentions the lift let alone identify all the pieces. The Build and Price is no better. I'm hoping that mine is just too new to have it available for customer distribution but who knows?
X35
PA
2025 Wrangler Willys XR
For my ‘25 Willys X35, I can view my complete build sheet on the Jeep app. It’s listed under the digital glove box section of the app.
Texas Longhorn
West Texas
2025 Mojito Sport S
Retired, with a good income.
Found that true as well for my 2025 Sport S. However it’s not available via the online search.
  • Like
Reactions: X35
jmr
Jim
Wentzville, MO
'24 JL Rubicon Unlimited, '25 JT Mojave
rahtx
Dallas, Texas
2025 Wrangler JLU Willys XR
I know this doesn't answer your question since mine is a Willys, but here is what is listed on my build sheet in the Jeep app under "Other". I highlighted what I believe is related to the XTREME 35" tire package.
. FRONT LED FOG LAMPS
. AUTOMATIC HEADLAMPS
. MOLD IN COLOR BUMPER W/GLOSS BLACK
. BLACK GRILLE
. DANA M210 WIDE HD TUBE FRONT AXLE
· INJECTION MOLDED BLACK REAR BUMPER
. DAYTIME RUNNING LAMP LED ACCENTS
. FULL SPEED FWD COLLISION WARN PLUS
. 2.0L 14 DOHC DI TURBO ENGINE W/ ESS
. BLACK 3-PIECE HARD TOP
. FRONT LICENSE PLATE BRACKET
· 4 ADDITIONAL GALLONS OF GAS
. E-LOCKER REAR AXLE
. CONVENTIONAL DIFFERENTIAL FRT AXLE
. CUSTOMER PREFERRED PACKAGE 22W
. MIC RUBICON HIGHLINE FLARE
. ALL AUTOMATIC TRANSMISSIONS
. MOPAR ALL-WEATHER FLOOR MATS
· CUSTOMER PREFERRED PACKAGE 2TW
. GVW RATING - 6250#
· SPRING - RIGHT REAR
. SPRING - LEFT REAR
. SPRING - LEFT FRONT
. SPRING - RIGHT FRONT
. 50 STATE EMISSIONS
. 97 MPH VEHICLE MAX SPEED CALIBRATION
. BF GOODRICH BRAND TIRES
. ALL RADIO EQUIPPED VEHICLES
. ROCK PROTECTION SILL RAILS
· REAR WINDOW DEFROSTER
. ANTI-LOCK 4-WHEEL DISC PERF BRAKES
. ADVANCED BRAKE ASSIST
. APPLE CARPLAY
. WHEEL FLARE EXTENSIONS
· JOOSE
. 4G LTE WI-FI HOT SPOT
. WILLYS
. ADAPTIVE CRUISE CONTROL W/STOP
. 17X8.0 MACHINED WHEELS W/BLK POCKETS
. NON-LOCK FUEL CAP W/O DISCRIMINATOR
. SECURITY ALARM
. PREMIUM WRAPPED STEERING WHEEL
· SELEC-SPEED (TM) CONTROL
. 35" TIRE SUSPENSION
· SIRIUSXM RADIO SERVICE
. REAR WINDOW WIPER/WASHER
. FOR MORE INFO, CALL 800-643-2112
. CLUSTER 7.0" TFT COLOR DISPLAY
. HEATED FRONT SEATS
· BLACK
. CLOTH LOW-BACK BUCKET SEATS
. POWER HEATED MIRRORS
. AUX BATTERY
. DEEP TINT SUNSCREEN WINDOWS
· LT315/70R17C 113/110S TIRES
. NO SOFT TOP
. SUN VISORS W/ILLUM VANITY MIRRORS
. DELETE 4-WHL DRIVE SWING GATE DECAL
. AIR CONDITIONING W/AUTO TEMP CONTROL
· 8-SPD AUTO 850RE TRANS (MAKE)
· FREEDOM PANEL STORAGE BAG
· 4.56 REAR AXLE RATIO
· DANA M220 WIDE REAR AXLE
. 2-DOOR PASSIVE ENTRY, FRT DOOR LOCKS
This is what was listed on my window sticker:
XTREME 35–Inch Tire Package
17–Inch x 8.0–Inch Machined Wheels w/ Black Pockets
4–Wheel Drive Swing–Gate Decal Delete
LT315/70R17C 113/110S Tires
Hinge–Gate Reinforcement by Mopar®
In my recent shopping, I found that the info on the window sticker is wildly inconsistent. Some mention the 4.56 gears and/or the performance brakes. None that I found mentioned the suspension lift or knuckles.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Use the FCA Vehicle Information Tool to get build sheet and window sticker.
It looks like that site has been blocked by Stellantis. Nothing but 403 responses. They can try getting around it by using VPNs, etc., but newer vehicles aren't available via API anymore anyways.
bcupton
Bob
St Louis Mo
25 Wrangler Rubicon X
Retired Navy
I guess I’m missing something. What’s the difference between the build sheet vs window sticker?
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
This should have been on your Jeep when you bought it? Or are you talking about a special order? You get better axles, better brakes, iron knuckles, 4.56 gears, and a mild lift.
WAM
Thanks rahtx. If that's the build sheet I guess I'm not impressed. I was expecting parts breakdowns with part numbers and such. What springs? What shocks? etc.
Ratbert
PNW
Software Engineer
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Never seen anything with part numbers. That would be an enormous sheet. Even the dealers have a hard time differentiating between similar parts on the same years. There is a crowd sourced spring thread on the forum though.
WAM
Ratbert
PNW
Software Engineer
I have the window sticker. It doesn't even mention I have a lift let alone any details. Apparently the build sheet will confirm there's a lift...but again no details. I think I know most of it from watching YouTube reviews but I was hoping for more detail for a baseline for any upgrades.
I'm not sure the build sheet says anything about a lift, but I haven't focused on them in a while.
thedeatons
Boise, ID
24 Wrangler Rubicon X, 24 Gladiator Mojave X
1.5" longer springs than a standard Rubicon, and extended bump stops make up the "lift", in addition to the 35" (34.5" overall diameter) BFG KO2's tires that help lift it as well. Jeep uses the same control arms as all the other Wranglers, but you can buy the longer front lower control arms (LCAs) separately from the Mopar lift kit (between $50-$60 each), bolt them on, and correct the caster a bit on the front end (no alignment needed afterward). After that just swap out/bolt on replacement shocks as you go to achieve the ride you want... A $250 set of gently used Fox 2.0s greatly improved my "bobble" down the road...
  • Like
Reactions: X35
