Build Recommendations Please!!
Drew4xE
Andrew
CA
2022 4xE
Here's what I have: 2022 JLU Rubicon 4XE - Daily Driver
Here's what I want: 35" tires, 17 or 18" wheels with a wide stance (I like the poke). If lifting is required, it needs to be as smooth as stock. I'll be replacing the front bumper with an aluminum one with a wench.
Backspacing and lift recommendations please. I have searched until my eyes bleed. I know you guys know your stuff. 37" looks great but not for me at this time.
Thanks for your help!!
If this post was placed in the wrong forum - I apologize.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
If you don't go off road, you shouldn't see any rubbing with 35s and most reasonable offsets.
SLORubi
Stephen
Grand Rapids, MI
2018 JLUR; 2019 A4 S-line
I presume the rims on a 2022 Rubi 4xe are the same as my 2018 JLUR, meaning they are +44mm offset. I went -12mm and they poke about 1.5" outside the stock fenders. The higher the negative offset, the farther they will poke out.
I’m running Bilstein shocks, heard they have better road manners than Fox. I don’t know for sure if true, but I like mine and they’re cheaper.
Themistocles
Virginia
'03 Ram 2500 Cummins / 20 JLURD
Here are a couple pictures of mine on Method 701s with 35s and a 2.5 Clayton suspension. If this is the kind of "poke" you are talking about, the Methods are a great option. Before I put on the suspension the 35s worked great and did not rub at all for normal driving or mild offroad. They did rub a bit when I got really twisted up in rocks.
Jeep Wrangler JL Build Recommendations Please!! 1655849152661
Jeep Wrangler JL Build Recommendations Please!! 1655849219942
Finally, while the image is entertaining, I must caution about getting wenches with bumpers...hard to explain to the GF or wife.
GATORB8
CLT NC
While the image is entertaining, I must caution about getting wenches with bumpers...hard to explain the the GF or wife.
Whether it's worth it really depends on the size of the bumpers .
Drew4xE
Andrew
CA
2022 4xE
Well played sir! Winch it is!
Drew4xE
Andrew
CA
2022 4xE
What was the width of the wheels and offset or backspacing if you remember?
GATORB8
CLT NC
Here’s pre lift and first set of tires for comparison, 35x12.50, 17x8.5 +18
Jeep Wrangler JL Build Recommendations Please!! 17876EDF-20F1-425D-857D-F27482B0B3A8
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
I'd get 35 x 11.5 x 17 on the stock wheels and leave the rest alone.
