Brake bleeder tool
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
Guys, I'm going to Harbor Freights to check this $30 thingy. Do you have some recommendations? My Jeep is way up high, so I have changed my mind, I'm not going to the self-service shop. I can do it in my driveway. I will give myself a lot of time tomorrow, the weather is super nice too.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
That should work put I have never used one. Put if you have air in the ABS module the only way to remove the air is with a scanner and doing an ABS bleed.
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
Just get a buddy to pump the pedal...open each bleeder 2-3 times to get new fluid in the calipers. Keep your eye on the fluid level...
Lartie
Nashville,Tennessee
JL Wrangler
Auto repair
3-Ton Heavy-Duty Floor Jack with Rapid Pump (lifts higher than standard models)
6-Ton Steel Jack Stands (must support your exact weight)
Pittsburgh Pro Torque Wrench (to tighten lug nuts properly)
