Boat Side Slider Design?
Beowulf
Jeep Wrangler Rubicon Unlimited
Why is it that every boat side slider for the JL seems to have way more metal on the body than needed? There is a big wing going up the body in front of the door, a peak between the doors and small swoop behind the rear door. Why can't the body mounted portion be straight across lined up with the portion that runs under the doors?
Is there a structural need for this, or is it just an aesthetic choice?
Jeep Wrangler JL Boat Side Slider Design? 31070002-1Resized
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
Helps spread the load the body metal is just thin sheet metal so you don't want it to start bending the body as you come down on rocks
caged
Rodger
Elliot Lake, Ontario
1949 CJ3a 90XJ 00XJ 97TJ 18JLR
you want that body armour on the JL. i've seen a few vids of body damage, right above the rock slider. extra armour is extra protection and cheaper than a repair. paint it body colour, and it won't stick out as much.
Beowulf
I think the body colored paint will have to be the trick. Paint the portion that hits the body the same OEM color and left the boat side black.
