Blank screen on backup camera?
Cappy
Ann Arbor, Michigan
none
I got the same exact thing hapoen to me
In my 2021 a few weeks ago. I gave it a hard restart (hold power and select buttons for over ten seconds until screen restarts) and the camera came back after uConnect turned back on.
I just did a search here and found this thread. My week old Jeep backup camera started showing an all white screen with the back up lines.
Only think I did was morning I opened the fuse box and pressed them all down as everyone seems to recommend here. Then later noticed the camera was screwed up. I went back into the fuses and pressed them all down again, no joy.
I just tried the hard reset trick and it's working. Thanks!
My previous car, a 2019 Jeep Cherokee back up camera would go all distorted on me like an old tube TV. I discovered if I opened and closed the hatch back it would fix it for a month or two.
I did not feel like bringing my new wrangler to the deal for service so soon so I hope the fix holds.
Once I got used to having a backup camera, it drives me nuts when it doesn't work. I don't know how I did not run over several people and pets backing up in the olden days.
JbuckTN
Nashville, TN
2021 Wrangle 80th Anniversary - Diesel
I think that is a soft reboot @DavidArmen .
Here is the reboot process in a little more detail:
  1. Ensure your vehicle is in park and in “Run” mode.
  2. Press and hold down the volume and tuner knob buttons at the same time.
  3. Hold down the knobs for 10 – 20 seconds.
  4. After holding down the knobs, the screen should flash your vehicle brand name and then go dark. (you can let go of the knows at this point)
  5. After a few moments the brand name will return, the system will reinitialize, and it will return you to the main UConnect screen.
A reboot does wonders for the backup guidelines issue. That is a bug on the 8.4 Uconnect.
DavidArmen
Los Angeles, CA
2021 JLUR
Thanks for putting the steps in more detail for those who will need it in the future!
Devil6Dog
Todd
Gilbert, Arizona
2021 JLUR Snazzleberry, 2001 Jeep Grand Cherokee,
Thanks, woke up this morning and my 30 day old camera stopped working. was pissed. So thankful for the knowledge here
Gladius Nova
Gladius
2021 JL
Just had a black screen this morning when I’m reverse. Only 2500 miles. First time this has happened but I get the missing backup lines frequently.
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
2021 JLUR WITH 2,000 miles, back up camera went dark. Pressed Volume+Tune for 20 seconds, that fixed it. I’m at 4,000 miles and haven’t had the issue.
Bedd
Bill
Illinois
2021 JL rubicon 2 door
Do you have problems with the auto lock function as well? Our new JL has had the same problem as nd our auto door lock doesn’t work. I’m wondering if it all has to do with Uconnect.
Gladius Nova
Gladius
2021 JL
I sometimes have to press the button on handle 2-3 times for it to lock. My auto lock seems to work (while I am in the vehicle when it locks after 5 minutes of driving).
Frankralfano
Frank
North Bergen, New Jersey
'21 Nacho Sahara JLU
it happens more on my 21 than it did on my 18.
Same, no issues on my '18, but the '21 has it at least 50%, either no lines or one constant beep. Yesterday was the first day where it was completely black except for the check surroundings message. Dealer said they never heard of it???
Mark Elliott
Orlando
2026 Rubicon X 2-door
Thanks for this, worked like a charm. I made a note and saved it on my iPad for the “next time”. Lol
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Sometimes doing the UConnect reset is hard to trigger by the way you did ... with the radio knobs..
To reset UConnect, you can also, pull fuse F97 while your JL is running, wait say 10-15 seconds and then plug the fuse back in... now turn off the JL and then restart it... that usually, will get your cam right back...(unless there is a hardware issue) thanks to the UConnect reset.
Yellow arrow points to F97 .
Jeep Wrangler JL Blank screen on backup camera? F97 fuse marked
west tex
Skoro
2021 JL 2dr 80th Edition, 2017 Renegade Trailhawk
Retired, as in "Tired again"
When I first picked up my '21 JL, it had the backup camera issues. Took it back to the dealer repeatedly and nothing they did addressed the issue. Eventually they replaced the head unit and that finally did the trick. Haven't had a hiccup since.
