Bilstein 8100 - Rubicon X
jadmt
jeff
montana
the stock shocks are F 17.2 compressed and 23.5 extended front
and 17.74 compressed and 26.2 extended rear and the 8100's are close compressed but the extend length is 27" front and 29.5 rear so that might cause some issues when offroad with the coils coming loose. you would have to fully flex it out to see. with too much droop with out longer sway bar links can sometimes cause and issue.
Upnover
Michigan
None
I have the 2.5 fox shocks in 2-3” and don’t have an issue, the front/rear coils stay seated at full droop. I did get longer front and rear sway bar links. The rear stock links would contact the shock body.
Also made adjustments to the brake lines/ rerouted the emergency brakes. Easy to do.
TrustWonUSA
TrustWonUSA
texas
2024 Jeep Jl
Are the links you using bent differently for clearance?
Upnover
Michigan
None
No I found some rear adjustable synergy off Facebook. The front I have apex I think also off facebook but you can probably just move the rear links to the front and just get rear ones.
I had the front ones on the self is the only reason I didn’t do the move. .
Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
What about your wheels? I heard the stock wheels with backspacing bigger than 4.5” is going to cause rubbing with the shocks. Not sure whether the OEM Rubicon XR-Beadlock wheels are any better (I think they are closer to 4.67” backspacing) but that could still be problematic.
Upnover
Michigan
None
Zero issues with the stock XR wheels. Well my reservoir attaches differently in the front. Maybe the piggyback style has issues.
PotterJLUR
Kansas
www.youtube.com
2024 392 Rubicon, RAM TRX, Camaro ZL1 1LE
I just installed these on my Xtreme 35 option Jeep though I am running additional 1.5in of spring spacers front and rear extended Mopar 2in lift front and rear sway bar links and removed the rear 1in stock bump stop extension and added the mopar 2in lift rear bump stop extension for correct bump stops for 37"s.
TrentYoung
Trent
Phoenix
2024 Jeep Wrangler Rubicon X 4Xe
I just added the Bilstein 5160's on my 2024 Jeep Rubicon X 4Xe with 35" Nitto Grapplers and the ride and fit are perfect. The 5160's account for the extra weight of the hybrid battery and if lifted me right at 3"
PotterJLUR
Kansas
www.youtube.com
Are you claiming the 5160's lifted the Jeep 3 inches?
TrustWonUSA
TrustWonUSA
texas
2024 Jeep Jl
I have not heard this before, i did get a reply Suspension Lift (link above)they said they would work, kind of. Below was there exact reply:
”will work for the Rubicon but you can use even shocks for 1-1,5'' lifted suspension”
So the response did not give me the confidence I would rely on alone. Still looking into it.
TrustWonUSA
TrustWonUSA
texas
2024 Jeep Jl
Yes - I saw the vid in another post, which is what got me thinking on these Bilsteins to begin with. Thanks for taking the time to put that together
