Best tires?
ptp262
Paul
Cranford
2019 Rubicon 2 door
What are the best tires? 2019Rubicon, Original ones are BF Goodrich A/T... THANKS
jadmt
jeff
montana
round and black made of rubber.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I would point you to the tirerack.com
Put in your size and look at reviews, I personally like a tire that is lightweight or at least the same weight as stock.
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
Post up your intended usage. Ex. All highway, rock crawling, etc.
Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
Yes
Richard_JL
Larry
Boca Raton, FL
2026 JLU Rubicon 3.6L
IT Director
Ask AI for 5 questions you can answer to pick the best tires for your needs:
"looking for new tires for my 2019 wrangler rubicon. ask me 5 questions to get the best for my needs"
Nice — I’ll dial this in for you. The 2019 Wrangler Rubicon came stock with 285/70R17 (~33") tires on 17-inch wheels, but many owners move to 35" all-terrain tires depending on use and lift. (TireSize)
Before recommending specific tires, I want to understand how you actually use the Jeep. Answer these 5 quick questions:
1️⃣ What tire size are you planning to run?
Examples:
  • 33" (stock size)
  • 35"
  • 37"
This matters because different tires perform very differently at each size.
2️⃣ How much of your driving is highway vs off-road?
Approximate split:
  • 90% highway / 10% trail
  • 70% highway / 30% trail
  • 50/50
All-terrain tires are quieter and last longer on pavement, while mud-terrains grip better off-road but are louder. (Rough Country)
3️⃣ What terrain do you actually drive off-road?
Choose the closest:
  • Sand
  • Rocks
  • Mud
  • Forest / dirt trails
  • Snow / winter
  • Mostly overlanding / mild trails
4️⃣ What matters most to you?
Rank these if you can:
  • Quiet ride
  • Long tread life
  • Maximum off-road grip
  • Wet road safety
  • Aggressive look
  • Weight / MPG
5️⃣ Are you lifted or stock suspension?
Example:
  • Stock Rubicon suspension
  • Leveling kit
  • 2–3" lift
This affects what tires fit without rubbing and how they perform when flexing. (Quadratec.com)
Once you answer those, I’ll recommend 3–5 specific tires that match your setup (for example: KO3, Falken Wildpeak, Nitto Recon, Baja Boss, etc.) and explain why each fits your use case.
And if you want, I can also tell you which tires Jeep owners regret buying — that’s often just as useful.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
I’m finding Toyos to be excellent tires. I stopped buying BFGs about a decade ago.
