Baxter filter adapter
Kent24
Kent
Springfield
2024 Rubicon X
I purchased mine from my local 4x4 shop.
North ridge sells the and you should be able to fined a discount coupon.
https://www.northridge4x4.com/part/...mance-cartridge-to-spin-on-oil-filter-adapter
Will I stalling the adaptor void the warranty?
Will installing the adapter void the warranty?
roaniecowpony
Retired Engineer
Only if you get caught.
CarbonSteel
I bought the remote mount one to install along with a fan driven oil cooler and dual oil filter housing, but a cracked head or block took out my 3.6L before I could install it.
The remote mount with properly anchored hoses prevents the need to ever touch the POS plastic housing again which **should** minimize issues.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
My Willys although still under extended warranty will never see a dealer again after the 3 time I took it in for my free oil changers.
Last free oil change oil spilled every where and when I told them there is something wrong with the brakes I was told it is normal.
As I walked out for the last time. I said I will fix it myself.
Ended up air in the brakes and needed an ABS bleed . FIXED.
If you have to take it to the dealer the Baxter can be easily swooped out.
Save your used oil filter and cap just encase you need to see the dealer.
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
Why don't you cancel your extended warranty and get some of your money back? If it's never going to a dealer again you have no need for it, and might as well get some of your money back.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
Its a 3 party extended warranty. Not a jeep factory extended warranty.
The only time I may use it is if a motor or trans fails.
Last week I had to replace my leaking water pump at 27k and did it my self at a cost of $300.
I do ALL my own work on all my vehicles.
I have seen what others can do to even the simplest job.
jellis4148
Missouri
That's true. I guess keep it for something catastrophic. Even 3rd party warranties can be cancelled. Actually I believe all can be. We don't use Mopar warranty here. We use Zurich and they can be cancelled at any time.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I haven't even read my warranty.
My wife insisted on it after listing to the sales man sales pitch.
I had to finely give in.
jellis4148
Missouri
I would keep it for something expensive, but if you bought it from the dealer it doesn't matter if it is 3rd party or not it can be cancelled. Some dealers try to make it a pain to do, but they don't have a choice if you want to cancel it. Pisses the finance guy off cause he gets a charge back.
LT230SE
SF Bay Area
2024 JLR 2-Door 6MT
you had a water pump go bad at only 27k miles?? 😭
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
Not disagreeing with you in this example, but sometimes the bean counters override the decisions of the engineers.
I think "bean counter decisions" redistribute more often than reduce costs. Reduced cost upfront (tangible!) are converted to long term costs.
Terrymo
Terry
2023 JLURXR 3.6 ET
Well I only got a C+ in my college accounting class so I’ll have to trust you on this.
BobW
Bob
Ventura County
I'm just a chemist so your accounting training exceeds mine! 🙄
coupedncal
CoupednCal
SF Bay Area
2024 JLUR
Could someone explain the reason behind pumping air into the chamber before you unscrew the top oil filter? Is it to force oil out of the filter housing? What kind of air pump is that used in the Northridge video?
roaniecowpony
Retired Engineer
You use compressed air to push the oil out of the filter and housing so it doesn't run all over and down under the intake manifold, when you unscrew it. There's an valve in the body of the Baxter adapter that is a weak spring and ball which only requires a few pounds of force to open it and push the oil past it.
