Batteries - What's up with them?
Kenstaroni
Ken
Nashville, TN
2020 Jeep JLU Rubicon
It does not get rid of or replace the smart charging in the JL wrangler. After installing the Genesis, your charging system will still operate in "not so smart" mode, leaving your Odyssey batteries under charged.
There are some threads running around that make mention of disconnecting the battery sensor in order to force your alternator into 14V+ permanently. But I would be worried about over charging the battery during long trips, which will also destroy your battery.
Currently, I am looking into DC to DC chargers, and if I will be able to connect one of these in order to keep the Genesis system properly charged. But it's getting expensive!
I agree that the oem charging system is insufficient. I have not tried to disconnect the sensor, however it’s said to charge at 14.4v constant if you do, which should be plenty safe for the Odyssey batteries. I ended up buying a NOCO dual bank on board charger to keep them charged up.
Onward4x4
Onward4x4
Nima
Chicago, Illinois
www.onward4x4.com
2018 Jeep Wrangler JLU
Traveler
May want to check with Genesis, for some reason I don't think the Optima batteries will work with their setup.
I went with Odyssey for mine and have no complaints.
They say it can be any battery so long as it is a group 25 size battery. I went with the Optimas since I am in Chicago and according to the video above, the Optimas perform better in cold climate--at least that's what I am hoping for...
Kenstaroni
Ken
Nashville, TN
Yep you are correct, just double checked their website. Optimas are GTG with the genesis kit
unsavory
Jimmy
2022 JLUR XR 2.0T Auto, 2019 JLUR V6 Manual (sold)
Seems the voltage is 14.7 with the sensor disconnected. I just tried it this morning. Now I'm worried I might be overcharging my batteries on longer multi hour trips...?
Kenstaroni
Ken
Nashville, TN
I tried it myself for the first time this morning as well. I got an auto start service message and light upon startup. Turned the jeep off and plugged it back in and everything was clear again. In the threads I read I don't remember hearing about disconnecting it causing any warning lights. Did you have this issue when you tried it?
unsavory
Jimmy
I did not, no. And I specifically made sure to enable ESS on my drive to work this morning, and all is working as expected. Are you also using the Genesis dual battery system like me?
Kenstaroni
Ken
Nashville, TN
Yes. I'm running a tazer mini with ESS off upon startup, maybe that had something to do with it...not sure.
unsavory
Jimmy
I'm running the exact same system as well with ESS disabled on startup. It could be your battery voltage, as I've seen that error light and message before when my batteries weren't fully charged with a 12.84V resting voltage. It was intermittent though.
It may have absolutely nothing to do with the disconnected IBS sensor. Because I've had that light trip using the ESS when I still had the sensor plugged in.
Onward4x4
Onward4x4
Nima
Chicago, Illinois
www.onward4x4.com
Traveler
I am having an interesting ESS issue with the @Genesis Offroad installed. I called Genesis and I am told that Chrysler has designed the ESS to stop functioning each 6 cycles. I did not have any issues before but I never counted the cycles and so I find it all pretty bizarre that I am now getting a notice that ESS isn't working and needs to be serviced after installing the double battery setup. So I am puzzled...
unsavory
Jimmy
You can't be serious. You were told that it is supposed to stop working after 6 start/stop cycles, as designed by Chrysler?
Onward4x4
Onward4x4
Nima
Chicago, Illinois
www.onward4x4.com
Traveler
rolly
2020 JL Rubicon 2DR
Thanks!
They are Ion rims matte black series 171 and Toyo Open Country R/T 33x12.5 18s.
Very nice. Are the caps "push through" or do they just bolt on the face of the wheel. Trying to find a 8 hole wheel where I can also use hubcentric rings (which usually aren't compatible with push through caps).
CaptStarboard
Australia
www.brisbanejeepclub.com
2020 Jeep JL Wrangler Rubicon 2.2L TD - "Jacko" Punk'n Orange (Old - 2010 Jeep KK Cherokee)
Anyone find out what the stock battery group size is?
from my research on the forums, battery sizes on ESS JLs are:
Main: H6/Group 48 12.0625x6.875x7.5625” or 306x175x192mm LxWxH
Mini Battery: AUX14 - Group 400
