Bad wheel hub assembly??? Help
Yellow Cake Kid
Jeep
Brake Hub And Bearing - Mopar 68272624AC
VEHICLE FITMENT
YearMakeModelBody & TrimEngine & Transmission
2022JeepGladiatorHigh Altitude, Mojave, Overland, Rubicon, Sport, Sport S, Willys, Willys Sport3.0L V6 - Diesel, 3.6L V6 - Gas
2022JeepWranglerRubicon, Sport, Sport S, Unlimited High Altitude 4xe, Unlimited Rubicon, Unlimited Rubicon 392, Unlimited Rubicon 4xe, Unlimited Sahara, Unlimited Sahara 4xe, Unlimited Sahara Altitude, Unlimited Sport, Unlimited Sport Altitude, Unlimited Sport S, Unlimited Willys, Unlimited Willys Sport, Willys, Willys Sport2.0L L4 - Electric/Gas, 2.0L L4 - Gas, 3.0L V6 - Diesel, 3.6L V6 - Electric/Gas, 3.6L V6 - Gas, 6.4L V8 - Gas
2021JeepGladiator80th Anniversary, High Altitude, Mojave, Overland, Rubicon, Sport, Sport S, Willys, Willys Sport3.0L V6 - Diesel, 3.6L V6 - Gas
2021JeepWrangler80th Anniversary, Freedom, Islander, Rubicon, Sport, Sport S, Unlimited 80th Anniversary, Unlimited Freedom, Unlimited High Altitude, Unlimited High Altitude 4xe, Unlimited Islander, Unlimited Rubicon, Unlimited Rubicon 392, Unlimited Rubicon 4xe, Unlimited Sahara, Unlimited Sahara 4xe, Unlimited Sahara Altitude, Unlimited Sport, Unlimited Sport Altitude, Unlimited Sport S, Unlimited Willys, Unlimited Willys Sport, Willys, Willys Sport2.0L L4 - Electric/Gas, 2.0L L4 - Gas, 3.0L V6 - Diesel, 3.6L V6 - Electric/Gas, 3.6L V6 - Gas, 6.4L V8 - Gas
2020JeepGladiatorAltitude, Launch Edition, Mojave, Overland, Rubicon, Sport, Sport S3.6L V6 - Gas
2020JeepWranglerRubicon, Sport, Sport S, Unlimited Rubicon, Unlimited Sahara, Unlimited Sport, Unlimited Sport S2.0L L4 - Electric/Gas, 2.0L L4 - Gas, 3.0L V6 - Diesel, 3.6L V6 - Electric/Gas, 3.6L V6 - Gas
2019JeepWranglerRubicon, Sport, Sport S, Unlimited Moab, Unlimited Rubicon, Unlimited Sahara, Unlimited Sport, Unlimited Sport S2.0L L4 - Electric/Gas, 2.0L L4 - Gas, 3.6L V6 - Gas
2018JeepWranglerRubicon, Sport, Sport S, Unlimited Moab, Unlimited Rubicon, Unlimited Sahara, Unlimited Sport, Unlimited Sport S2.0L L4 - Electric/Gas, 3.6L V6 - Gas
Ozionjon
Jon
La Verne
2018 JLU sport
Figured id chime in. Ive had multiple hub Bearing failures
1st time 20,xxxx miles
2nd time 70,xxx miles
3rd time 100,xxxx miles.
Currently speaking to a lawyer about lemon lawing the jeep.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
You’re out of your f*ing mind if you think that qualifies.
azwjowner
Phoenix
Normally I'd agree but he's the guy who has had 3 driver's side bearing fail but is still on the original passenger side. Something must be misaligned in that axle. I'd think they'd just replace the front axle instead of a Jeep though.
mwilk012
Oklahoma
Service
They don’t have to do anything, he’s at 100k miles.
mwilk012
Oklahoma
Service
Well of course, but I just assumed it's some sort of goodwill program. Because it seems obvious something was defective with the axle.
Warranties have expiration points for a reason. Eventually you wear things out and tear things up and it’s on the owner.
azwjowner
Phoenix
Never mind, he's in California. There's no mileage or time period limit on the lemon law there. Since FCA first attempted the repair within the warranty period, it's probably covered. Of course if they were smart, Jeep would have replaced the axle instead of repeatedly replacing hub bearings.
mwilk012
Oklahoma
Service
It was repaired and complied with applicable warranty.
azwjowner
Phoenix
If someone wears out three driver's side hub bearings but 0 passenger side bearings, the problem isn't the hub bearing. So it hasn't been repaired. They've thrown parts at it, that's all.
Ozionjon
Jon
La Verne
2018 JLU sport
Yeah because it happened under the basic warranty it has been covered every time it failed.
My dealer is actually the one that recommended i contact an attorney.
mwilk012
Oklahoma
Service
if you drive 50,000 miles without a repeat failure, it’s fixed.
Ozionjon
Jon
La Verne
2018 JLU sport
Exactly!!
there’s no reason a hub to fail at 20,xxx miles on a stock JLU
mwilk012
Oklahoma
Service
Your dealer is doing you a major solid then. Why don’t you just fix your Jeep?
