Axle Ordering Questions - HELP!
kjl2020
DeKalb, Illinois
2020 Wrangler 2-Door
Greetings all, I am looking to order an axle direct from dealer. Part number is 68595277AA. Has anyone ever had experience ordering an axle from a dealer like this? This specific one says it is 4.56, I’m really hoping that means it comes with the gears installed, as well as axle shafts. Does anyone have input if it’s a “complete” axle with gears, shafts, etc? Or is it just a shell?
Maverick909
I.E.
www.instagram.com
I have ordered rubicon axles form the dealer with the factory 4.10 gears. came with everything except the brakes.
kjl2020
DeKalb, Illinois
what part number did you use to order them? 77072405? or some other one with two letters at the end
Maverick909
I.E.
www.instagram.com
I pulled it direct from the catalog it was P/N 77072405 but even in the catalog it states that the JT front with the extra two letters comes complete without brakes
El Zilcho
Max
San Diego
2018 JLU Sport, Rubicon axles
I ordered new Rubicon rear axle and it came with brakes.
Front might come without brakes because, sport brakes are a direct bolt on to Rubicon axle. Sahara and some other trims have the same brakes as Rubicon.
Maverick909
I.E.
www.instagram.com
The Sahara, High altitude and the willys XR come with the larger brakes
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Sport
Front: 330mm x 24mm
Caliper: 48mm (1.88")
Rear: 328mm x 12mm
Caliper: 45mm (1.77')
Rubicon/Sahara
Front: 330mm x 28mm
Caliper: 51mm (2")
Rear: 342mm x 14mm
Caliper: 48mm (1.88") (Sahara, Sahara 4xe, Rubicon, Rubicon 4xe)
Sahara 4xe/Extreme Recon
Front Caliper: 51mm (2")
Rear: 345mm x 22mm
Caliper: 51mm (2")
Rubicon 4xe/Rubicon 392
Rear: 350mm x 22mm
Caliper: 51mm (2")
