Hubtech
- Kyle
- Jul 23, 2018
- Hattiesburg, ma
- OB JKUR
DoIt....I'm curious about this as well.
OK, what about this... I got the 535T, What if i wired like you and only used the front two windows for up because they are already one touch down. Could we not then use the other two circuits for the rear windows up only? Not sure if this is a do-able thing or not, but it looks to me that you have four options for 1. all windows one touch up, 2. all windows one touchdown, 3. front windoows one touch up and one touch down, or 4. rear windows one touch up and one touch down. I'm thinking there are some iterations that could involve both. I'm not an electrician, I drive ships for a living. so, if you hear from me again it will be yea (with a schematic attached), or nay (with unhappy face attached). Or if you don't hear from me at all I probably blew up!OK, as promised. Here is a brief write-up of my adding one-touch up to my front windows.
1st, you need to obtain a module to help with this.I purchased the DEI 535T. I have used similar DEI modules with great success. This is their newest one and it works really well.
I removed the HVAC console. It just pops off so work your way around the edges and pull:
Next you remove the window switch control panel, there are two screws:
Next I tested the wires with a voltmeter:
My wire colors were as follows:
Driver Up: OG/GN
Driver Down: OG/W (thick wire)
Passenger Up: OG/BN
Passenger Down: OG/V
I only wired the Up switches because the Down switch is already one-touch.
Next I just followed the instructions for wiring the 535T. You have to splice the Jeep wires so be sure you cut with enough room to splice the wires back together in the future if need be. I zip tied the 535T module behind the glovebox.
I plsan to do the rear windows at a later date. This will require another 535T.
Here is a video of the final product:
https://www.supermotors.net/getfile/1139153/fullsize/video.mov
Couple things (and I am going of memory) however: 1) If you wire all four windows on one unit, you can only do auto up I believe and it only works with an alarm type unit, so for example you arm the alarm, all four windows go up. There is no one touch feature with four windows wired 2) I believe you could in theory wire the front to auto up only and the rear to auto up or down but not both. 3) Your 3 & 4 scenarios I believe are viable.OK, what about this... I got the 535T, What if i wired like you and only used the front two windows for up because they are already one touch down. Could we not then use the other two circuits for the rear windows up only? Not sure if this is a do-able thing or not, but it looks to me that you have four options for 1. all windows one touch up, 2. all windows one touchdown, 3. front windoows one touch up and one touch down, or 4. rear windows one touch up and one touch down. I'm thinking there are some iterations that could involve both. I'm not an electrician, I drive ships for a living. so, if you hear from me again it will be yea (with a schematic attached), or nay (with unhappy face attached). Or if you don't hear from me at all I probably blew up!
To answer this question, yes, I believe you could wire the rear up only with the other two circuits...OK, what about this... I got the 535T, What if i wired like you and only used the front two windows for up because they are already one touch down. Could we not then use the other two circuits for the rear windows up only?
I thought about it but have not. Need to figure out what wire(s) to use.Did you hook the arm input up to the factory keyless/alarm, an aftermarket alarm or nothing? I’m going completely from memory which isn’t very good. If I remember correctly the DEI window modules should give you one touch up and down without having them hooked to an arm/disarm input? I have a couple window modules kicking around I was thinking of using for that purpose. I do miss the one touch up & down, being able to vent and have them roll up with an alarm arm on a pervious car. It was very nice.
Is this the wiring diagram you followed?OK, as promised. Here is a brief write-up of my adding one-touch up to my front windows.
Driver Up: OG/GN
Passenger Up: OG/BN
