WannFly
I got this compressor a long time ago, will be installing it under passenger seat next week. Little confused on which coupler I need. Thoughts?
Compressor: ARB CKMTA12 from amazon
ARB under seat mounting bracket: ARB 3550220 Compressor Bracket System For Use w/CKMTA w/CKMA Or CKSA Compressor Bracket System
On ARB website there are 2 couplings and I am unsure which one to get
ARB - 0740112 - Air System Hose Coupling (arbusa.com) OR ARB - 0740111 - Hose Coupling (arbusa.com)
Also, for those who have installed it under seat, it looks like I might need an extension hose? if so, can someone recommend which one and which 90 degree elbow fitting I might need?
Looks are these are the ones, but need to confirm: ARB - 0740201 - Reinforced Stainless Steel Braided PTFE Hose (arbusa.com) and ARB - 0740104 - Air Line Elbow Fitting (arbusa.com)
Do I need anything else?
I will be running the wires under the body through the drain plug, the pax fender is already off, so would be easier to run the wires from there and connect the purple wire to Aux 1 or 2 with an inline fuse.
