ARB Pressure Control Airflow
jeronimo
Krazysphere
2018 Jeep Wrangler Unlimited Rubicon JL
On the trail :+)
Hello guys, I decided to post this here hoping there would be someone who knows the math behind calculating airflow better than me.
To cut the story short I bought into the ARB Pressure Control and while planning on installing it for use with my ARB twin compressor I noticed the tiny input/output holes of the solenoids. Both solenoids have three 2.1mm diameter holes as input and a single 2.1mm diameter hole as output obviously regulating the pressure.
I am planning to use this with a four tire system to inflate and deflate my tires simultaneously, but I am trying to figure out if and how airflow would be affected by the the solenoid input & output.
Any ideas are highly appreciated. Here are some picture of the manifold and its components:
Jeep Wrangler JL ARB Pressure Control Airflow IMG_9326
Jeep Wrangler JL ARB Pressure Control Airflow IMG_9328
Jeep Wrangler JL ARB Pressure Control Airflow IMG_9335
Jeep Wrangler JL ARB Pressure Control Airflow IMG_9344
Jeep Wrangler JL ARB Pressure Control Airflow IMG_9345
jeronimo
jeronimo
Krazysphere
On the trail :+)
To make the question more clear I am wondering how this ARB Pressure Control manifold and valves would affect inflation and deflation times given previously I would inflate straight off the ARB twin compressor with a four tire system and deflate through the four tire system alone :movember:
Nissan
Nissan
israel
JL
Hey
I use the same systems as you tagged
Arb Twin Turbo
four tire system kit
The system works fine; there is no need to change anything, just a little slower in filling the air because the system stops for a few seconds to check for pressures.
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
You can get similar control valves with larger ports on Amazon. Used in pneumatic control systems.
bobholthaus
Bob
St. Louis, MO
2023 JKURD AEV JL370; 2014 GC Overland Diesel
Technology Integrator
Reviving this; what ever happened? Worth using the Pressure Control system with a four-tire inflation/deflation system? Thanks.
Orange County, CA
2021 JLURD
a single 2.1mm hole will flow more (greater than 6 scfm) than the output of the ARB twin at inflation pressures, so its not a restriction there, deflating will restrict to around 4 scfm. more likely that any restriction really comes from any obstruction of those hole from the actual solenoid valve.
