kapk22
- Kasey
- Apr 19, 2020
- San Antonio Texas
- 1990 YJ, 2021 JLUR
holy crap!!! You were not kidding. The arms are MASSIVE. Kind of a chore getting them in. Very happy. Thank YouYou’ll be surprised when you get the arms by how beefy they are, they’ll work fine with the Mopar kit. In the rear you can just get a track bar relocation bracket if you want. It raises the track bar which will center your rear axle.
The main reason you don’t just use a relocation bracket in the front is because it raises the track bar which gets it out off parallel with the drag link, which leads to bump steer.
As far as a steering stabilizer goes, IMO , I would get a thru shaft ss since your going with 37/13.50s. You can wait to see how your oem ss does, and decide then. It’s not something you have to do right away. If you do go with an ats ss, I would relocate it to top of the tie rod, to get it out of harms way as well. The synergy relocation kit is what I used before I got my new adjustable thru shaft ss , it has its own tie rod clamp.
it’s just a matter of adjusting them correctly now.
