Any fix recommendations for P1DB1 obd code???
macturn05
Michael Brian
Houston, Texas
2018 Jeep Wrangler JL 4dr
I just had a check engine light today. Any recommendations to fix this issue? Thank you in advance.
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
P1DB1 - Transmission Control Module System Voltage Excessively Low
Check to make sure all your fuses are seated properly. Then see if your ESS is working. This will mean your batteries are charged. After that, it's dealer service time.
macturn05
Michael Brian
Houston, Texas
Thank you! It’s all working even my ESS and I check all of the fuses. Do I still need to go to the dealership? I still have warranty. Ty
JeepU4IA
Rod
Los Angeles
Maybe the transmission control module has actually gone bad or your batteries are going bad. Either way, definitely take it in. The technicians will need diagnotic tools to troubleshoot the culprit. There aren't any more home remedies. Keep us updated.
