P06DD error code, any step by step guides to fix?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
I have this code also. I started with full oil level, the Mopar filter, ensured the plastic valve thing was in there too, I replaced the oil pressure sensor, replaced the oil pump, had the timing chain kit redone because of a broken tensioner I found while doing the pump, replaced the wiring harness leading to the oil pressure sensor, and reset the code after every one of these repairs. I still have the P06DD and it's driving me mad. What else can I do?
Replace the engine.
Probably lots of other things too. Try testing and replacing the actual problem.
JO DYRT
Orange County, CA
www.clickonpc.com
2018 Wrangler JLU Sahara
IT Professional
2018 JLUS around 65K miles. I hade the PO6DD code come up and go into limp mode 3/4 to my destination to Mojave Valley, AZ. After checking to make sure what the code meant and verifying I had oil and pressure. Turning off the engine for a bit I was able to get it out of limp mode and make it to my destination and took it too dealer next day, they said they saw only a store code and everything looked fine and cleared the code. drove around all weekend and close to home it happens again.
I take it to my dealer they check it all out and say they are going to replace the oil pump solenoid, then all is good.
A couple months pass and it happens again, take it in and they said they are going to replace the Pump and seals per FCA. All is good after that.
A couple months and at 580miles from last visit it happens again. last time they said if it happens the engine will likely be replaced. So they order an engine when I bring it in and waiting for FCA to approve. I now have a new 2.0 engine in a Jeep with 65K on it.
The jeep no longer sounds like a tractor when it is cold at start. I will hope it will keep sounding like this down the road. Less than a week of having it back and all is good.
Hope this helps some one that has the P06DD code.
