Ambient Lighting System Upgrade
rcadden
Ricky
Asheville, NC
Marketing
I really love this but it looks like for those, you'd have to pick the color when you order - i.e. these are NOT RGB LEDs, but rather single-color that is chosen at purchase.
Has anyone seen an RGB option? I'd like to have blue as the default, but be able to switch to white easily. Blue is more "fun" but there may be situations when I'd want a more clean white light available.
Anyone seen this?
DavidArmen
DavidArmen
Los Angeles, CA
2021 JLUR
Anyone seen this?
You are correct these are not RGB. The only way you could use RGB LEDs is if you used the jeep wiring as power only and then used a remote control to change the colors. However, there is another issue because I the system is dimmable and the dimming feature would not work with RGB LEDs so the scroll wheel would need to always be turned all the way up and stay there, otherwise there will be flickering and other issues.
navyflyer
“Chopper” Bob
Ponte Vedra, Florida
2021 Rubi
Airline pilot
Thanks David. Project complete. Disconnected the stock white led footwell light plug and installed a pair of red leds on each side. One is connected to the door/dome wire and the other is connected to the dimmable flood. Pretty simple install, got the leds from superbrightleds.com (they have other color options). Put the ground wires together in one connection. Only trick is the led wires aren’t labeled +/- so use a 9v battery to see which wire is which. LEDs work one way only so polarity matters.
Jeep Wrangler JL Ambient Lighting System Upgrade 852472D2-559C-4132-B916-F651AB43E1A0
Jeep Wrangler JL Ambient Lighting System Upgrade 2FEF16D2-205B-4F76-A6DF-1F17A198C345
Jeep Wrangler JL Ambient Lighting System Upgrade BFC33835-18B2-4DAD-826B-9B5476A37FAE
Jeep Wrangler JL Ambient Lighting System Upgrade 6EA36948-79FD-42EE-B425-92B76378C575
Jeep Wrangler JL Ambient Lighting System Upgrade 046BC09B-5F13-4A81-AF35-A77E2AE5D589
Jeep Wrangler JL Ambient Lighting System Upgrade B163FE13-31F8-4A41-B63D-F8ECC981B736
Jeep Wrangler JL Ambient Lighting System Upgrade 94201C53-0833-452F-A7C7-D6E6576845CC
DavidArmen
DavidArmen
Los Angeles, CA
2021 JLUR
That is amazing work! It looks great! I need to take some time to replace my t-taps with posi-taps
rcadden
Ricky
Asheville, NC
Marketing
I think I'd prefer something like that. My challenge is I don't really want another switch to light them up. I *do* have the AUX switches in my JLU, which are currently unused, so I guess I could use that for now and then move them later if I needed the switch.
BXFXJeep
Toronto, ON
2021 4xe Sahara
These light up once I fire up the Wrangler since it's off the cigarette lighter, I also didn't stick them on, I use the zip times they came with to secure them under the seats, the wires are hidden in the plastic moldings etc, install takes about 15 minutes.
I'm sure these can be rigged up to use something other than the cigarette lighter, but I prefer not to splice wires etc if I don't have to.
DavidArmen
DavidArmen
Los Angeles, CA
2021 JLUR
So you have that long bulky plug permanently plugged in to the center console cigar lighter?? I would opt for not putting any ambient lighting at all if I had to power it using the center console cigar lighter.
  • Like
Reactions: GtX
BIGW0RM
Orange County, CA
23 Raptor // 22 M3 Comp X // 20 RRS
Thanks for posting this. I just did this mod myself. I used some red license plate led lights and those posi t taps. I mounted them under the dash and rear seats
I used these lights. Two sets, 8 total.
https://www.amazon.com/gp/product/B08R59W2H7/ref=ox_sc_act_title_1?smid=A15M0OICGLE6ZP&psc=1
I did two per side front and back. One light connected to the ambient light. One connected to the courtesy light. Looks freaking awesome! I will post pics soon.
