Amazon 7" adapter looks promising
weeitsmikelee
New Jersey
‘21 Wrangler 392; ‘22 Grand Wagoneer; '15 Harley Sportster; '82 Honda Silverwing
Healthcare
Nice write up! Thanks I’ll be trying to do this over the weekend
Capt-Zoom
Capt-Zoom
North
2019 JL sport s, 4door. 1999 TJ Sport
Excuse my ignorance but why do you need these? Are you converting to LED?
Alanscott1
Central NJ
2024 2dr Sport 6spd
A&P Mechanic
Presently there aren't many 9" LED aftermarket headlights for sale, however, 7" LED models are plentiful. These adapters simply allow you to use 7" lights in a 9" application.
blnewt
blnewt
New Mexico
Just ask @cosine he knows!
Thanks for the detailed pics and info! I also ordered from the Amazon Sup-light vendor, hopefully mine will be complete w/ the rubber spacers. Looks like a pretty good install, and not having those screws showing makes for a clean install, looks better than any of the other 7" adapters that I've seen :)
These allow you to use previous 7" JK lights on your JL if you weren't fortunate enough to get the LED upgrade.
Capt-Zoom
Capt-Zoom
North
Ah. Had a feeling it might be something like that. Thx.
weeitsmikelee
New Jersey
Healthcare
So Sup-Light actually didn’t provide rubber gaskets until 12/18/18 onwards but they are sending me a pair anyways which is nice of them. I installed mine ahead of time since I’m waiting for more buckets or adapters to hit the market.
There’s definitely a 1.5 inch gap but it’s fine for now.
Jeep Wrangler JL Amazon 7" adapter looks promising 274A0C4D-561C-48D9-BCCC-6CA442941C64
Jeep Wrangler JL Amazon 7" adapter looks promising 1AB947F4-4A38-4372-9B52-AC3FC8F46A88
Jeep Wrangler JL Amazon 7" adapter looks promising 075EDD76-723D-45CE-87A4-E3F244A8BDEB
Jeep Wrangler JL Amazon 7" adapter looks promising 8B222072-ED56-4554-AD68-D3CBEDAA4E39
blnewt
blnewt
New Mexico
That's good that they're sending them to you, should clean up the look quite a bit. Seems like this is the best option available for a more finished look, at least from all the adapters I've seen, and some costing 2x as much or more!
emilboya
Emil
TX
Hummer H3 (Sold) & Jeep JL
Process Engineer
Could you send me a link to the 7" Headlights you are using?
weeitsmikelee
New Jersey
Healthcare
blnewt
blnewt
New Mexico
Got mine today, got them in about 10 days and they did come w/ the outer rubber rings, look to be well constructed, look forward to getting these installed when Jeep gets home :)
weeitsmikelee
New Jersey
Healthcare
Yeah, they're decent for what they are. They adjust easily and get the job done. The rubber rings do make it look a bit better. Have fun!
emilboya
Emil
TX
Process Engineer
Just finished my install!
Jeep Wrangler JL Amazon 7" adapter looks promising 5AAF41F5-143E-4728-9750-F0CF140565AD
Jeep Wrangler JL Amazon 7" adapter looks promising 7A713DEC-9FCA-4F63-9FD2-D32B35D8BD97
  • Like
Reactions: zyt
blnewt
blnewt
New Mexico
Looking great, and on that black JL just about perfect!
blnewt
blnewt
New Mexico
Got our JL a couple weeks ago, installed split halo LEDs w/ the Amazon SUP-light adapters today, haven't adjusted them yet but look to be close out of the box.
Wired the DRLs to fuse 57 w/ a Amazon Micro fuse tap. I was going to run it to a switch in the dash but decided I didn't want to drill into any panels (might at a later date). I haven't wired the amber turn signal switchbacks might do so down the road. The plug in adapters that came w/ the SUP-light mounts worked perfectly and I had to use the anti-flicker CANBUS adapter included w/ the lights to get high beams to function perfectly. All-in for about $200 so am very happy so far, will update if any problems occur. There is a bit of a gap from the back of the headlight grill cutouts to the front of the headlight edge so I may add some spacers if this ends up bugging me. From the front the fit looks great IMO.
Jeep Wrangler JL Amazon 7" adapter looks promising 100_4030
Jeep Wrangler JL Amazon 7" adapter looks promising 100_4031
Jeep Wrangler JL Amazon 7" adapter looks promising 100_4032
Jeep Wrangler JL Amazon 7" adapter looks promising 100_4033
Jeep Wrangler JL Amazon 7" adapter looks promising 100_4034
Jeep Wrangler JL Amazon 7" adapter looks promising 100_4035
